I bet that T cackles with that exhaust Dave.
Is the exhaust mounted to the swingarm? Can't tell from the picture.
Of course. The picture isn't that clear.
The bike is looking good. Have you been able to figure out if the chrome cylinders are on or if they got switched out for iron liners or something else?
Nope. Won't worry about it until this winter when I'll pull off a head.
you don't have to pull head, drop sump and put a magnet to the cylinder wall.
Yes, but that only tells you the material, not the condition of the bore. I'll get a camera in there and see what it looks like.USB Borescope, Vastar 2.0 Megapixel CMOS HD USB Endoscope Waterproof Handheld Borescope Digital Inspection Camera Snake Camera(5 Meter Cable) https://www.amazon.com/dp/B01HGKMWMA/ref=cm_sw_r_cp_tai_ooFQxbVT75RF2
Hey Dave, that's pretty cool on the bore scope. I have one that is a seperate hand held unit. Cost more too.
True. But if it's chrome, condition is immaterial. I'll say it again: IMO, there is no such thing as "good chrome bores". If they're chrome, they need to be replaced/replated/sleeved as soon as possible. If it's Nikasil or iron liners with compression and leakdown numbers within spec. then that pretty much tells you everything you need to know without a borescope or removing a head.
Got one of these and yes I know it's Harbor Freight.http://www.harborfreight.com/catalogsearch/result?q=digital+inspection+camera
