Ambient was my word and I take your point re the intake being under the tank
No, no, you're NOT wrong using the term. I think most manufacturers refer to it as a Intake Air Temperature sensor, and most descriptions of an IAT would probably use the term "ambient" as the air isn't being specifically cooled or heated for a purpose.
I'm just noting that the location of the Guzzi intakes and their IATs probably has an effect on that air temperature.
And I don't have a single guess as to why they chose that parameter. I would have expected closed loop operation would only depend on:
* Throttle position and engine rpm (steady not WOT or accelerating)
* Combustion chamber temperature (fully warmed)
* 02 sensor temperature (the signal is only reliable once it comes up to temperature)
Maybe combustion chamber temperatures are never really sufficient or proper if the IAT sensor isn't seeing at least 64F (18C) on the CARC bikes. This would go along with Pete's observations that the CARC bikes might indeed be over-cooled.
