Author Topic: V11 LeMans oil pan (sump) on a 1998EV?  (Read 4663 times)
Offline Strom
    • Moto Guzzi Slovenia forum
« on: August 08, 2016, 02:05:47 AM »
Hey guys...
I really hate to pull the oil pan every time I change the oil filter on my 1998 EV. Also I tend to not ride slowly and it gets hot where I tour the most so I guess an oil cooler would be welcome.
There is a V11 LeMans sump+ring+oil filter entrails on ebay and I wonder if it would fit a 1998EV. (also if the filter can be changed without removing the whole sump?)
Auction ends in about 10h, so any quick replies would be welcome.... pretty please... it is cheap (at the moment) and I cannot afford expensive. :)
Since everyone has their list of bikes in their sig... and it seems useful, here we go:
1979 Yamaha XS 1100
1984 Moto Guzzi V35 II
1998 Moto Guzzi California EV
2001 Aprilia RST1000 Futura
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: V11 LeMans oil pan (sump) on a 1998EV?
« Reply #1 on: August 08, 2016, 04:45:37 AM »
Should fit, Just look at what on the outside can be in it's way. exhaust pipes, sidestand? The frame isn't the problem.
Paul
Daytona 1225, Stelvio 1151
« Reply #2 on: August 08, 2016, 05:13:12 AM »
You'd be better off with an outsider oil filter kit.
The manhole cover can be pain on the V11 Sport/LeMans.
In over 40,000 miles, I never used the cover, but dropped the pan at each oil change.
« Reply #3 on: August 08, 2016, 05:46:44 AM »
Is this a "wide sump"?
Offline Strom
« Reply #4 on: August 08, 2016, 06:58:09 AM »
This... why would the manhole cover be a problem?
« Last Edit: August 08, 2016, 06:58:54 AM by Strom »
1979 Yamaha XS 1100
« Reply #5 on: August 08, 2016, 07:02:52 AM »
the threads are fine and delicate, easy to cross thread.
« Reply #6 on: August 08, 2016, 08:18:44 AM »
Yep.  Back in the day, there was lots of talk on v11lemans.com about the troubles/issues with frequent use of the manhole cover for oil changes.
Plus, if you're hip and using a hose clamp on the filter, the pan will have to be dropped at filter changes.
« Reply #7 on: August 08, 2016, 08:19:20 AM »
"Broad Sump".  Yes.
Offline Strom
« Reply #8 on: August 08, 2016, 08:37:53 AM »
Thanks for the input guys! :)
I guess I will rather use the sump extender with the outside filter... front or back, what do you recommend?
I guess the front is more prone to damage from... whatever... and the back might get in the way of the H-pipe?
1979 Yamaha XS 1100
« Reply #9 on: August 08, 2016, 02:03:27 PM »
Sorry to be butting in on the discussion, but there's a detail here I'm trying to understand.
We're discussing putting an old school (normal, narrow . . .) and outsider on sump and an outside on a wide sump engine.
The cautions from the commenters isn't that it doesn't bolt up or that it's bad for the engine, the cautions are that even with an access plate for the filter, you want to pull the sump to change oil.
So I'm concluding that a standard sump -- from say an EV --  fits where a wide one did, and swapping is no danger to the engine.  Is that correct?
« Reply #10 on: August 08, 2016, 03:45:08 PM »
The way I understand it:
-The OP has a '98 EV.  No Outsider.
-The OP has seen a complete V11 broad sump for sale and would like to retrofit to his Cal EV to ease oil filter changes, and as a secondary benefit use the V11's oil cooler.
-The OP has been advised that it would be easier and more practical to add the Outsider to his stock EV.
-The OP has been advised that adding the broad sump can be done, but if he does so, don't use the manhole cover.  Drop the pan to change the filter.
-The OP has not been advised to try an Outsider on a broad sump.
« Reply #11 on: August 08, 2016, 04:45:19 PM »
If it will fit, and I can't see why it shouldn't but I've never tried, the only real *advantage* I can see would be the ability to use an oil cooler. Since an oil cooler is completely un-necessary unless you habitually ride on the sunny side of Mercury I can't see any real benefit to the swap. And yes, you'd need the filter/OPRV/Thermostat mount as well.
« Reply #12 on: August 08, 2016, 06:37:08 PM »
But if I was adapting a wide sump engine to a Cali EV, being able to use the cali sump could head off installation clearance problems.
So I'm trying to sort out if that's doable -- also if it's necessary, or does a wide sump fit in a cali?
The alternator isn't an issue, since I have one running via v-belt from the drive shaft.
If I can get through the compatibility issues there may be a 2006 Breva 1200 engine in the trike's future.  But if the front cover, sump, or flywheel won't fit, or if there are different header or intake sizes, then I can't do it.
« Reply #13 on: August 08, 2016, 06:41:01 PM »
OK, now you're talking carrots to our apples and oranges.
Breva is a whole 'nother deal.
The Griso/Breva/Norge/Stelvio's sumps are different from the V11 broad sump we're discussing.
And that won't be your problem.  The high mounted alternator interfering with the top rail of the Tonti frame will be the issue to work through.
« Reply #14 on: August 08, 2016, 06:56:55 PM »
I'll throw the alternator away to make the space.  Don't need it.
But to get back to educating me -- you're saying the sumps interchange -- no issues?
Does the wide sump fit in a tonti frame?
Offline radguzzi
« Reply #15 on: August 08, 2016, 07:33:12 PM »
I guess I should let the OP know, or anyone else interested, I have a complete broad sump from a V11 For Sale...
PM for details if you have any interest in this one.
And just as an FYI, the covers can be troublesome however, if you can deal with the fact that the bottom of the pan and the recessed threads for the access cover are on two different angles, the threading of the door is not such a big ta-do, My Opinion Only.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
« Reply #16 on: August 08, 2016, 07:36:11 PM »
People have put wide sump V11 Sport/LeMans engines into Tonti frames.  Todd@Guzzitech, for one.
The Breva engine is different from what the original topic of this thread is about.  I have not heard or seen anyone putting a Breva/Griso/Norge engine into a Tonti.
« Reply #17 on: August 08, 2016, 07:46:11 PM »
To use a CARC bike engine you'd just need to swap the timing chest cover. Ground clearance might be a bit of an issue as the sump on the CARC engines is deeper. Depends how ply the Trike is?
« Reply #18 on: August 08, 2016, 08:09:36 PM »
The only hassle I have with dropping the pan is making sure I have a replacement gasket just in case.
« Reply #19 on: August 08, 2016, 08:29:41 PM »
Thanks, Pete.  The trike is at the same ground height as the 2-wheel version since I used the oem forks, steering head portion and lower rails (gotten from yourself, and a tip of my hat for that!).  So I think this might be a go.
Sorry for the deviation from the topic.  I'm ignorant enough to not know those engine differences, but curious enough to hijack the topic in order to find out.  Returning you to the topic now in 3.  . .2 . ..1 .. .
Offline pehayes
« Reply #20 on: August 08, 2016, 10:13:22 PM »
The G & G (Switzerland) deep sump with recessed filter is what you want.  Not cheap, but a fine piece of kit.  Currently out of stock.
http://www.mgcycle.com/index.php?main_page=product_info&products_id=4586
Offline Strom
« Reply #21 on: August 09, 2016, 04:34:10 AM »
Thanks for all the replies guys... I have been away from this board for a while, but it is great to see you are not dead yet. ;)
So, I skipped on the wide sump thingie on ebay.. but I might be interested doing it later on, if I standardize my cali.
Your input is really very much appretiated :) Also the offer w/pics. :)
I love the looks of the deep sump with external filter, but yeah.. a tad more expensive than I would like, so I guess I will get an "outsider". The question still remains, the one where the filter is at the back or in the front?
How is the H pipe clearance with the filter at the back?
Rambling, ignore:
Also, I think I will find whoever designed the wiring on 98EV and talk a bit about his mother... but that is another topic... (headlight relay gets hot??? When I checked the wiring diagram I am confident everything runs on magic). Also white vaguelia rev counter dead (now I have two dead ones... the small winding around the magnet failed on both of them, pretty much the only thing that is not easily fixable).
1979 Yamaha XS 1100
« Reply #22 on: August 09, 2016, 12:09:31 PM »
You need to ask the mfgr about the H-pipe question.  They make different units for different h-pipe configurations.
The filter is in the rear, on the right.
