Author Topic: hydraulic clutch conversion thread  (Read 18489 times)
Offline Motosan
« on: August 12, 2016, 12:58:02 PM »
Just checking if anyone has a good resource on hydraulic clutch conversion for a tonti frame? I'm bored and tempted to convert my SP1000 as the new clutch is SO heavy, especially in the city traffic I'm cursed with. In the threads here I see people have used the MG Cycle slave kit or the Magura jack kit but perhaps there's more options out there. If you have any good resources or suggestions let me know.
Offline swooshdave
Re: hydraulic clutch conversion thread
« Reply #1 on: August 12, 2016, 01:05:03 PM »
I've wondered if there was a way to adapt a diaphragm spring like on the Commando. I have mine set so it's a one finger pull.
Or if there's a way to get better leverage on the Guzzi.
But it seems like dropping a couple hundred on the hydraulics still may be the easiest.
2001 V11 Sport
Offline acguzzi
« Reply #2 on: August 12, 2016, 02:07:52 PM »
mgcycle have a hydraulic slave, I used that with a used clutch master from a modern bike
Offline Motosan
« Reply #3 on: August 12, 2016, 02:13:03 PM »
I've wondered the same. For instance if the Easy Pull clutch adapter benchmark works makes for airheads could be used.
Offline Idontwantapickle
« Reply #4 on: August 12, 2016, 02:54:41 PM »
You can use the lever assy from a later bike such as the Mille or it's close relatives. They have a much easier pull.
Have you replaced the cable lately? Worn cables are hard on the hands.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline flangeman_70
« Reply #5 on: August 12, 2016, 03:09:36 PM »
I am just modifying this to fit my Centauro now so the fast idle lever is in the normal position.
http://www.ebay.co.uk/itm/PBR-Mecdraulic-Typ-60-MOTO-GUZZI-/151924387826?hash=item235f662ff2
On my SPIII I have a Magura setup which I purchased from Venhill in the UK which is very similar, more expensive and uses mineral oil instead of brake fluid. It is fantastic in operation, I've done 35000km's with it without issue but it is a PITA to bleed.
FWIW, the hydraulic is much easier on the hand in city riding, the slave cylinders for both types look like they were made in the same factory but with a different finish on the metal.
Adam
Adam
SP III 1990
V10 Centauro 1996
Offline guzziownr
« Reply #6 on: August 12, 2016, 08:05:57 PM »
I used a Ducati 916 clutch M/C with the MG Cycle slave on my Jackal.  it was one-finger light.
Offline Motosan
« Reply #7 on: August 14, 2016, 09:22:24 PM »
Seems like Magura is a good way to go since it's a complete system and you order the slave cylinder size you need. There's some good videos for setting them up as well.
https://www.youtube.com/watch?v=vwyzJ_2uPuw
Offline swooshdave
« Reply #8 on: August 15, 2016, 12:30:16 AM »
I would be great to hear from someone who has install this kit.
2001 V11 Sport
« Reply #9 on: August 15, 2016, 02:58:18 AM »
Doesn't Magura use mineral oil instead of DOT-whatever?
I'm asking because there are folks with hydraulic clutches on their guzzis that have had odd fluid-related problems.  If I was thinking about converting, I'd try whichever fluid they're not using.
Offline brlawson
« Reply #10 on: August 15, 2016, 07:21:51 AM »
http://radicalguzzi.com/motor_getriebe
The folks at Radical Guzzi continue to offer a very nice option that neatly plugs into the back of the trans and deletes all the movable parts. Mgcycle used to sell these back when this guy's father made them when it was called Moto Spezial. Prices now are much more reasonable.
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
Offline salsaman1964
« Reply #11 on: August 15, 2016, 10:17:28 AM »
I'm using a Frando set up on my lemans 3 and it works a treat. It is Korean made and excellent quality. I've added a link to the supplier who ships world wide and takes payment in US dollars.
Venhill in the UK are agents but more expensive. Frando also do a radial master cylinder to suit. You will need to source a braded lines and fittings to make it work on your bike
http://japan.webike.net/products/21851004.html
Regards Tony
Offline Motosan
« Reply #12 on: August 15, 2016, 12:13:37 PM »
I like that Frando has a radial master cylinder for a reasonable price but how would one know what to order? Magura is nice because you get a complete setup.
Regards Tony
« Reply #13 on: August 15, 2016, 12:19:54 PM »
See my original post  :cheesy:
See my original post  :wink:
Adam
Check the PBR kit in my original post,it is complete :Beating_A_Dead_Hors e_by_liviu
Adam
SP III 1990
V10 Centauro 1996
Offline swooshdave
« Reply #14 on: August 15, 2016, 12:51:20 PM »
Adam
There are a bunch of variables with the Magura clutch kit. Do you recall the details of your setup or part number? Or did you just tell them "big Guzzi"? Do you have photos? Was it as simple to install as the videos make it out to be?
2001 V11 Sport
« Reply #15 on: August 15, 2016, 02:11:04 PM »
The items below are directly from my invoice from Venhill minus prices. I bought it in March 2013 and the Master cylinder was being phased out. It has a decomp lever on it which I use as the choke on the SPIII. Price was then £330. Expensive!
I am extremely happy with it and it's performance. I ride year round in filthy conditions in winter, city stop & go and am a daily commuter, no corrosion, no leaks, no fuss except for bleeding it and needing the 'Blood Oil'.
In my opinion you would be best served with the PBR kit from the e-bay link, the slave is the same part but with a different finish, the master is a regular Brembo item (i.e. service parts are easy to find) and it uses DOT brake fluid. Mine will be fitted in the coming weeks.
I'll get some pics tomorrow of the Magura.
MISC. FITING 0120576 163 M/CYLINDER
3H1350-CL 1350mm CLEAR HOSE - 1/8 BSP SWIVEL NUTS
3/60100AC MALE ADAPTOR 10x1 X 1/8 BSP CHROME
3/60061C M6 STRAIGHT BANJO CHROME
0430224 HYMEC FLANGED SLEEVE FOR SLAVE
0412310 HYMEC 9/8mm SLOTTED BARREL NIPPLE 724.12
0722152 HYMEC SERVICE/BLEED KIT
0722136 HYMEC HOLLOW SCREW WITH BLEED NIPPLE
0120652 HYMEC SLAVE CYLINDER
Good luck!
Adam
Adam
SP III 1990
V10 Centauro 1996
Offline Lesman
« Reply #16 on: August 15, 2016, 03:04:56 PM »
I don't know squat about the hydraulic set up for your particular bike. I've done a little research for for my Quota. It's one of those solutions in search of a problem. Guzzi makes a slave cylinder ready to go plus a clutch master cylinder. Say you you don't want spend $250-$300 for a MG based solution. PIT bike setups on EBAY runs around $32.00-$49.00 dollars+/- They are ready to go. Some come with mirror mounts some don't. The hose lines appear to be either 900mm or 1200mm. Lot's of older Japanese bike redo's are running this setup. It's just an idea.
an example M9Zg&vxp=mtr" class="bbc_link" target="_blank" rel="noopener noreferrer">http://www.ebay.com/itm/1200mm-Hydraulic-Clutch-Lever-Master-Cylinder-125-250cc-Dirt-Pit-Bike-Motorcycle-/111958213590?var=&hash=item1a113ac3d6:m:mv2lrGBClEruLPcsxn8 M9Zg&vxp=mtr
Good luck,
Les
Offline bigbikerrick
« Reply #17 on: August 15, 2016, 03:08:35 PM »
 Just in case someone decides to go with the magura setup....My son's KTM RC 8 has a magura master cylinder for the clutch. I use the same aviation mineral oil based hydraulic fluid that I use in my converts fluid drive system. ( as Rodekyll recommended) It works great and is WAY cheaper than the magura "blood" as they call it. They do seem to require bleeding about every couple of months to  eliminate air bubbles,that develop with usage. I have read on KTM forums that that is just the nature of the beast.
Rick.
« Last Edit: August 15, 2016, 03:17:01 PM by bigbikerrick »
Offline swooshdave
« Reply #18 on: August 15, 2016, 03:41:39 PM »
Good luck,
Les
Will those little systems have enough oomph for the Guzzi clutch? Is 1200mm going to be long enough?
2001 V11 Sport
Offline Lesman
« Reply #19 on: August 15, 2016, 06:05:30 PM »
The Hose is the question. Custom "Ebay"hose  can be had reasonable. I'm not here to claim cheapness over quality is the way to go. I've seen slave cylinders in the less than $15 range. It's just a cheap option.
Speedway  racing has slave cylinders for $34.99 that require some modification. As I stated earlier MG has everything almost bolt on through the miracle of money. The only thing stopping me is a Harley buddy. He does doesn't think an Hydraulic Clutch on a Quota is an "enhancement". The clutch action my bike is super easy. I looked at a bunch of XS650, Honda and Sportster hydraulic clutch  setups. All these bikes had one thing in common. They all had different handelbars setups from stock. They went this way instead of a custom clutch cable. Bang Good is a nother source of pit bike hydraulic clutches.
Best regards,
Les
Offline MotoG5
« Reply #20 on: August 15, 2016, 09:09:41 PM »
Ran the set up from MG Cycle using the recommended Brembo 13mm left hand master connected with the suggested brake line kit for about seven years on my wife's 93' Cal III. When I bought it Stine Dense was selling it but the MG unit is the same one that they were selling. She needed an easier clutch pull due to carpal tunnel surgery. Not a big deal to install and a very solid reliable set up used in all kinds of weather with out issues. When she was diagnosed with cancer and became unable to keep riding a the Cal I pulled the system and sold it to a dude in Australia on E-bay. Refit the original clutch set up and rode the Cal III myself until I replaced it with my present Stelvio. If you want a straight forward hydro clutch set up that's durable and easy to live with I would recommend the one from MG.
Nebraska MGNOC State Rep
Offline swooshdave
« Reply #21 on: August 15, 2016, 09:53:33 PM »
These are Guzzi owners, I don't think they know about the easy way.   :smiley:
2001 V11 Sport
Offline taz
  • 2003 Aprilla RSV Mille, 2007 Moto Guzzi Norge
« Reply #22 on: April 15, 2018, 10:50:37 AM »
Anyone do a hydraulic conversion on a 750ie Breva.   My wife needs an easier clutch pull.
"We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm."  George Orwell
Offline Diploman
« Reply #23 on: April 15, 2018, 12:02:25 PM »
I know several KTM single owners who have fitted Frando radial MC's and clutch slave cylinders to their bikes with good success.  Available easily from Japan WebBike, who take USD payment and ship expeditiously.  Frando, incidentally, is not Korean but Taiwanese.  Very good quality for a reasonable price.
Hydraulic lines for a clutch should not be a problem.  MG Cycle carries the Magnum line of BYO hoses and fittings, while Revival Cycle in Austin has the Goodridge line of BYO hoses and fittings.  I built all the brake lines for my V50 at home with Magnum components, and they are flawless.  Besides being less expensive than pre-made hoses, BYO has the advantage of being able to get the exact length and configuration you want.
2015 KTM 390 Duke
Offline Vagrant
« Reply #24 on: February 20, 2021, 06:20:13 PM »
I thought I'd revive this old thread before I call MG cycle and order their setup. My 2001 EV is 15 1/2 LBS. all lubed up and a good cable.  the old hand can't handle it anymore. It's in Az with few tools and little patience to jury rig. Anyone have something better to look at first?
Offline Rich A
« Reply #25 on: February 20, 2021, 09:02:54 PM »
I used the slave from MG Cycle and a 13 mm (I think) Brembo MC. I made the hydraulic line, using Magnum build-it-yourself hose and fittings (0 deg for slave, 35 deg for MC). A banjo with a bleeder makes bleeding easy. Very happy I did this.
Rich A
Offline Vagrant
« Reply #26 on: February 21, 2021, 02:27:36 PM »
can you tell me how much it reduced the effort?
Offline Rich A
« Reply #27 on: February 21, 2021, 09:34:09 PM »
I just checked it with a (probably not very accurate) fishing scale. It's cold out, around freezing. The hydraulic clutch showed about 11-12 lbs, measured just inward of the knob on the clutch lever. The stock clutch on my Bassa that's being parted out and has been sitting for a couple of years showed about 15 to 17 lbs.
The clutch on my V7III read about 10-11 lbs, but it has a Pazzo short lever.
Rich
« Last Edit: February 21, 2021, 09:53:26 PM by Rich A »
Offline Vagrant
« Reply #28 on: February 28, 2021, 06:33:13 PM »
I bought the whole setup from MG cycle. Great folks to deal with and fast service. This is what it looks like and IF it is truly letting the clutch fully engage and disengage, WOW! better than I had hoped for. the old unit was basically 16 LBS this is basically 4-11 LBS. It's hard to say as there is virtually no pressure then it goes up to maybe 11 then drops to 4 when fully held in.
The concern is the tiny nylon lock nut that holds the barrel into the back of the clutch lever has no threads left out the back. it looks like it seemingly needs a longer shaft to let it fully engage. turn it in a few turns and it slips. because of the hydraulic tension even at rest, there is no free play like on a cable unit. real test ride tomorrow.
06222839 Brembo steel banjo bolt 1.0 x 10mm, silver N
finish
2.00 4.51 9.02
10467014 Brembo 13mm left hydraulic clutch master N
cylinder, black lever
1.00 113.71 113.71
14023760 valve cover gasket square fin big twins N 2.00 2.42 4.84
17412461 clear Magnum BYO brake hose, 6 foot section N 1.00 22.46 22.46
17420298 Magnum BYO brake banjo fitting 180 degrees, N
straight
1.00 15.26 15.26
17420299 Magnum BYO brake banjo fitting 35 degrees N 1.00 15.26 15.26
25656100 10mm copper sealing washer, brake hose N
applications
4.00 1.52 6.08
MG5050 Hydraulic clutch assembly, slave cylinder N
without pump
1.00 125.49 125.49
Balance: 0.00
** THANK YOU FOR YOUR ORDER ** PLEASE READ STORE POLICES ON OUR WEBSITE **
** NO RETURNS WITHOUT PRIOR AUTHORIZATION- NOTIFICATION REQUIRED **NO RETURNS AFTER 30 DAYS **
** NO RETURNS ON SPECIAL ORDER, CLEARANCE, SALE PRICE, SPECIAL OFFERS, OR ELECTRICAL PARTS **
** 20% RE-STOCKING FEE ON RETURNED MERCHANDISE **
Tax:
Shipping:
Total: 331.07
18.95
0.00
SubTotal: 312.12
Prepaid:
Paid: 0.00
upload png
Offline jhem68
« Reply #29 on: March 01, 2021, 12:29:40 PM »
I have two early tonti's with this setup. A 1975 T and a 1980 SP 1000.
I set up the T originally with the same components Vagrant is using about three years ago and the threaded rod that the barrel fits on is definitely longer than the model I purchased last year when I decided to set the SP up with the "wrist Relief Clutch Springs", AND the hydraulic set up.(The SP now has a clutch pull that is almost as light as my Milano).
The early version worked fine on my T and after installing the lighter springs (along with a new SD tech 4mm clutch upgrade) on the SP I felt the SP was still too much effort for the rather severe arthritis in my left thumb and so I pulled the early unit off the T and installed it in the SP. The longer threaded rod required an adjustment to the arm at the back of the transmission otherwise it foul against the brake pivot on the SP. The 850T has a rear drum and a completely different brake pivot system. So perhaps that is why the newer slave cylinders have less threads and a shorter overall length.
When I finally got around to replacing the hydraulic set up on the T, I also had trouble with getting enough threads without some clutch slippage and it required an adjustment at the clutch arm to find the correct combination.
These are somewhat self adjusting units and both of mine will adjust to zero clearance as far as I can tell so I have no Idea if there is some slight pressure on the throwout bearing or not and that does leave a small concern in my mind but only time will tell as I do not use either of these two for my everyday driver.
For those who question why anyone would go through the trouble of doing this, in my case I wouldn't be able to ride in stop and go traffic without this modification due to my arthritis.
The current setup on the 850T
 and the SP
P.S> A little adjustment at the clutch arm goes a long way.
« Last Edit: March 01, 2021, 12:39:37 PM by jhem68 »
