Author Topic: jackal fueling issue  (Read 2917 times)
Offline brenwin
  • Easy does it .
« on: August 12, 2016, 04:28:33 PM »
I'm posting for a buddy who just bought an 01 Jackal . At a steady an even throttle the engine sputters but as soon as more gas is given the bike runs fine and pulls without a miss .
He's had the throttle bodies balanced and replaced the fuel filter .
The bike was temporarily better after the throttle bodies where balanced but shortly after is back to the same sputtering when at steady throttle only .
I'm wondering if air is getting in somewhere !?
Any suggestions as to what the problem is will be appreciated .
Cheers ,
Steve
2015 Griso 1200SE
2004 V11 Ballabio (red)
1973 Eldorado
Re: jackal fueling issue
« Reply #1 on: August 12, 2016, 04:35:30 PM »
 Mine stumbles at low rpm's and low throttle openings . Is he letting it rev a bit ?
Offline brenwin
  • Easy does it .
« Reply #2 on: August 12, 2016, 05:23:56 PM »
He says it's fine while under throttle but while cruising at an even speed it stumbles and is not smooth . It's definitely a little rough at low revs .
Hard to define when it's not my ride . I told him to sign up here and get the goods first hand from you guys .
Thanks ,
Steve
2015 Griso 1200SE
1973 Eldorado
Offline Kev m
« Reply #3 on: August 12, 2016, 05:24:54 PM »
How sure is he about the condition of the TPS?
« Reply #4 on: August 12, 2016, 05:32:38 PM »
  :1: Of course I go back to my original question , mine runs fine at any thing above 2K RPM's , but is a bit fluffy below that . No tach , just guessing at the engine speed , but betting that figure is close . Opening the throttle always cleans things up .
« Reply #5 on: August 12, 2016, 05:48:42 PM »
You should not chug along like a Harley can, tell your bud to rev it up, run a lower gear or two.
Could spray something around the intake path to look for air leak.
And possibly the TPS needs a reset.
Offline brenwin
  • Easy does it .
« Reply #6 on: August 12, 2016, 07:48:23 PM »
That's a good idea and will pass along .
I know the TPS was diagnosed and set when he had the throttle bodies balanced at Valley Moto .
Cheers ,
Steve
2015 Griso 1200SE
1973 Eldorado
Offline Kev m
« Reply #7 on: August 12, 2016, 08:13:22 PM »
I would have expected them to reset the TPS as part of the balancing (as the adjustments would affect the TPS adjustment), but I wouldn't have assumed that they would check the whole operational range for flat spots.
That said, lugging would be a nice explanation.
« Reply #8 on: August 12, 2016, 08:50:47 PM »
Has it had a basic tune-up -- plugs, valve adjust, etc?  What is the condition of the ignition/plug wires?  OEM exhaust?  Air filter dirty?  Is his tank vent stuff working, and does he overfill it?  As we've discovered in recent topics, a saturated carbon can might make it stumble.  What happens if he pulls the evap hoses to the TB's?
That's all I got off the top of my head.  I gotta go out and see why my Honda outboard is cutting out at low rpm.  It's acting like fuel, so I'm checking the wires.
Offline brenwin
  • Easy does it .
« Reply #9 on: August 14, 2016, 01:27:40 PM »
I'll pass this along and thanks for the info , you too Kev and everyone else who responded . Hopefully he'll get it sorted . Good luck with the outboard !
2015 Griso 1200SE
1973 Eldorado
Offline brenwin
  • Easy does it .
« Reply #10 on: August 14, 2016, 01:31:34 PM »
All checked and on the diagnostics at the dealer (one of the better mechanics) , TPS reset , ran good for a while afterwards then started to lag at steady throttle again . rev it and all good ! He'll get it figured , or won't !
2015 Griso 1200SE
1973 Eldorado
