Well, I had Guzziology and I had a CX100 also some 10 years ago. But I very stupidly sold the CX100 to some nice gentleman from Arkansas when I left the U.S at the time and gave him the book in a random act of kindness. I guess it's time to buy it again. I loved the CX100 but I prefer the 850 engine so I don't regret it too much. The CX100 was never produced in Europe and I would have had to go through a lenghty and costly homologation process to import it.I am afraid that's what the problem is. The fork of the LM1 is narrower than the SP's but the disc rotors appear to be the same on both models. So I guess what gives are the wheels though they look pretty much the same. Steine-Dinse lists the same wheels for LM1/2/3 (not available for sale anymore) but a different model for the SP though it's not totally clear in their diagrams databaseYou may be right. The best solution is maybe to leave it as is. Spoke wheels look better anyway. Rather than investing in old "rotors", I could be better off investing in a set of floating new brakes...but I am a sucker for the "original" look.
My understanding is that the SP and Convert cast wheels in fact are wider at the hub. In effect on these models the spacer is built into the wheel casting I know this because I converted my T3 from spoke to cast wheels and needed the wider casting from an SP so as not to need spacers and that was the case on the front wheel. That made it an easy direct bolt on. The narrower (at the hub) cast wheels from the LM would have required a spacer to fit on my T3. So for the LM you need the narrower hubbed wheel.
