Author Topic: small block oil feed hose  (Read 2394 times)
Offline Yard Sale
  • If wishes were horses, we'd all be eating steak.
« on: August 13, 2016, 12:33:00 PM »
I can't find it in the Breva 750 or Nevada 750 parts manuals. The oil hose that screws into the back of the sump. Can somebody give me a part number or point me to the page in the part manual?
I've searched for oil, line, hose, galley, pipe, and looked at all the pictures. It's like they forgot it.
Offline sib
Re: small block oil feed hose
« Reply #1 on: August 13, 2016, 12:52:33 PM »
The equivalent hose on the 1TB V7's is B063213.  It's shown in the parts manual on the page for the airbox.  On the Cafe Classic 750, the part is number GU32159310.  Guzzibits shows them as being identical.  Dimensions: 7mm ID x 12mm OD x 200mm, and states "Fits Moto Guzzi Breva 750, Nevada 750 (2004-), V7 Cafe, V7 Classic, V7 Stone, V7 Racer".
There's also a fiber washer, GU90714082, which is the same for both models.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Yard Sale
« Reply #2 on: August 13, 2016, 03:16:19 PM »
Thank you very much, that's the one. Just a breather, huh.
« Reply #3 on: August 13, 2016, 03:53:16 PM »
Not a breather, it's the condensate return to the sump from the separator.
Offline v65tt
    • Streffords
« Reply #4 on: August 13, 2016, 04:04:17 PM »
Have blanked of the sump hole and removed the pipe on every Guzzi I have owned
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
Offline sib
« Reply #5 on: August 13, 2016, 04:26:08 PM »
So, all of your blow-by oil then accumulates in the airbox and then gets burned in the engine instead of being condensed and returned to the crankcase?  How much oil does your bike consume?  Mine consumes none at all between oil changes.
Offline v65tt
    • Streffords
« Reply #6 on: August 13, 2016, 04:39:31 PM »
Valve cover outlets are connected to 8mm fuel hoses routed to rear near number plate
Air box has all pipes blanked off. Just air inlet and outlets to the carbs
Did 650 miles last week  inc some off road, all 2 up with top box and panniers, not used a drop since I changed 1500 miles ago and still lovely cherry red.
Breathers spit Mayo out even after 650 miles in 5 days.   Don't want that in my sump
To be fair my Guzzi is unique...
« Last Edit: August 13, 2016, 04:46:53 PM by v65tt »
Iain
1986 V65TT
