Author Topic: Nissan-variable compression engine-NGC  (Read 2104 times)
Offline chuck peterson
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Phang
Re: Nissan-variable compression engine-NGC
« Reply #1 on: August 15, 2016, 01:20:43 AM »
a glorified Atkinson cycle engine?  :popcorn:
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline not-fishing
« Reply #2 on: August 15, 2016, 04:12:23 AM »
I'm waiting for camless engine.
Dropping the cam and associated parts will really free up horsepower.
http://blog.caranddriver.com/koenigseggs-camshaft-less-engine-explained-watch-it-in-action-video/
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline brlawson
B. Lawson
Madison, AL
'72 Suzuki Titan 500
'77 Yamaha RD400
'79 BMW R/65
'03 California Titanium
'10 Stelvio ABS
2000 v11 Sport
« Reply #4 on: August 15, 2016, 10:32:33 AM »
http://www.reuters.com/article/us-autos-japan-nissan-engine-idUSKCN10P0IK?il=0
I wonder how it works?  Maybe closeted combustion sub-chambers?  Retractable head?
The article had no explanation of the mechanics and tech.
« Last Edit: August 15, 2016, 10:33:25 AM by LowRyter »
Offline pikipiki
« Reply #5 on: August 15, 2016, 11:21:42 AM »
I suspect it's just a variable geometry turbo or it could be inlet valves that can be controlled to stay open through the initial part of the compression cycle Nisan already do that with Dig-T and Dig-S engines.
Fiat have developed hydrolic valves to replace inlet valve cams.
Saab prototype had true varialble compression 10/15 years ago.
« Reply #6 on: August 15, 2016, 11:30:41 AM »
Here is the first one ......
 :laugh:
Offline Testarossa
    • Skiing History
« Reply #7 on: August 15, 2016, 11:43:02 AM »
For a number of years MAN B&W and Warstsila have been building marine diesels with electrohydraulic valves and no camshafts. Like the Freevalve design, they use a rail to control the variable valves along with fuel to the injectors. Being able to open and close the valves more than once per rev enables a two-stroke cycle. These are huge main-drive engines for container ships.
Offline ITSec
« Reply #8 on: August 15, 2016, 01:48:52 PM »
Formula1 has been camless for a while - and has used some fairly exotic combinations of long-shaft turbos and hybrid power-scavenging that could actually be applied to mass production products.
The new Nissan design, effectively changing the length of the connecting rods, is a very distinct design; till now, compression changes have largely been done through variable valve timing. VVT can be done with both cammed and camless designs, and may be less mechanically complex than the Nissan approach - though with less range of compression variability.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
