Oh yeah, I've read that if you have a screen on the bike (I do), the vacuum/vortex created behind (in front?) of the reservoir may be enough to suck a small amount of fluid out.Again, I'll let you know once I've cleaned and refitted everything.
Really?That sounds most unlikely. I have a screen and I don't get leaks.Have you had the top off lately? Have you tried just tightening up the screws? If that doesn't work,then just clean carefully and refit.
Have listened to advice here. Unscrewed, cleaned and put back together. Problem solved.Thanks
