Author Topic: Unusual sound 1999 Bassa with audio- advice please!  (Read 5055 times)
Offline toukow
« on: August 19, 2016, 12:23:06 PM »
I was hoping you guys could give me some advice. First, I am having a heck of a time getting the .MOV video to load to Photobucket, so I changed course and used Youtube for the first time. Then finally Photobucket showed the uploaded video and a link from there is included as well.
 I have not ridden this bike much (has 16K miles), and it has always started without issue or unusual sounds. I started it yesterday and heard the noise which starts at 12 seconds into the video. It sounds like a loud repetitive 'clack' sound. It stopped after 30 seconds or so. It sounded like it was coming from the transmission area, not the engine.
I am not positive on this, but it appears to only happen when cold. When I started it after a 30-minute ride I heard nothing unusual, and no noise while underway.
Is there a throw-out bearing failing or clutch issue? Could the starter gear be failing to retract completely?  Your comments appreciated. Thanks, Toukow
http://vid1246.photobucket.com/albums/gg617/toukow/IMG_0158.mp4
https://youtu.be/YeuzdecjiBs
1999 California 1100 Bassa To Be Decided
2008 FJR1300 Rain Bike
2008 Aprilia Tuono 1000 Sunny Day Bike
1995 VFR 750 Simply The Best
Re: Unusual sound 1999 Bassa with audio- advice please!
« Reply #1 on: August 19, 2016, 01:55:10 PM »
Does the sound change when you pull the clutch lever? If so its the floater in the clutch and complety normal
« Reply #2 on: August 19, 2016, 03:06:02 PM »
odd click sound. sort of random sequence not what I expected to hear as a clutch sound which would be rhythmic .. maybe get a stethoscope.
Offline chuck peterson
« Reply #3 on: August 19, 2016, 04:03:28 PM »
With your motor off, turn the rear wheel slowly, while feeling for resistance...might be a ujoint in its early stages of destruction
I keep buying used bikes that have sat for....a decade sometimes...and the ujoint area can collect moisture in the rubber sleeve area from heating and cooling over the seasons...rust pits form, then suddenly it's put back into action, and the joint fails from the thorough scrubbing in a rust bath...ymmv, but it's my best guess
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #4 on: August 19, 2016, 04:06:29 PM »
 Uh Chuck , the U joint isn' t turning
Offline RinkRat II
  • Lake Powell AZ
« Reply #5 on: August 19, 2016, 05:35:40 PM »
 Have you listened to this sound from the other side of the bike too?? Confirm or deny your starter theory with a stethoscope or long screwdriver at the starter attachment point on the bellhousing. :popcorn:
   Paul B :boozing:
Offline bikeridertim
  • Just ride it!
« Reply #6 on: August 19, 2016, 06:58:34 PM »
Hi All, Might sound funny, but It sounds to me like the exhaust (or crossover) expanding as it heats up.
My 99 EV with 143000 miles does the same thing
Tim
« Last Edit: August 19, 2016, 06:59:41 PM by bikeridertim »
2018 Honda Goldwing
1999 MOTO GUZZI EV11
1973 MOTO GUZZI ELDORODO
MGNOC L-201
AMA LIFE MEMBER 543509
IRON BUTT 12038
We struggle our whole lives so that we don’t have to struggle.  Huzo
LaMojo
« Reply #7 on: August 19, 2016, 08:00:11 PM »
My 98 EV occasionally has clicking sounds like that for years . Mainly after a cold start.  I always assumed it was one of the dogs in the transmission too close to a gear.  Only happens when in neutral and I've never had a problem with the transmission.
« Reply #8 on: August 20, 2016, 06:42:53 AM »
Well what da  ya want?  im making up answers as fast as I can...why would I let the facts get in the way? :thewife:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline twhitaker
« Reply #9 on: August 20, 2016, 07:28:36 AM »
LOL! Have you thought about running for office?
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Online Chuck in Indiana
« Reply #10 on: August 20, 2016, 11:45:19 AM »
My advice? Earplugs..
« Reply #11 on: August 20, 2016, 11:55:30 AM »
  :laugh:
 Yeah , not a precedent we care to establish ...
Online LowRyter
« Reply #12 on: August 20, 2016, 12:20:06 PM »
sounded like normal to me.
Offline toukow
« Reply #13 on: August 23, 2016, 09:26:43 AM »
Thanks guys for the review. I pulled the starter and cleaned and lubed the solenoid plunger just in case. The noise has not returned over the last 4-5 starts, but I'm guessing that is just a coincidence. Will update post if it returns. Thanks again, Toukow
I hope this is the exact situation then. The transmission on this bike is extremely smooth with zero clunk going from neutral to first, which was contrary to what I had expected given comments from others (uninformed) on Guzzi's in general.
Tim
Guess it could be this but it happens so quickly after starting that I'd be surprised. Also, it's not the usual exhaust tick with which I'm familiar and I would guess this would occur with every cold start.
Have you listened to this sound from the other side of the bike too?? Confirm or deny your starter theory with a stethoscope or long screwdriver at the starter attachment point on the bellhousing. :popcorn:   Paul B :boozing:
I do have stethoscope and will do it if it occurs again.
Agreed. It's quite random and so far has only lasted about 30 seconds or less.
I will definitely give this a go if it returns. Thanks!
Offline screamday
« Reply #14 on: August 23, 2016, 10:12:51 AM »
Same here.......just assumed it was the exhaust expanding as it heats up. Mine only does it after it sits overnight. As far as the noise happening right away....I don't think it takes very long for the heat from the motor to start heating up the exhaust. Anyway.....mines been doing it 18 years.
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
Online bad Chad
« Reply #15 on: August 23, 2016, 10:36:33 AM »
Agreed, your over thinking it.  Go with Chuck's suggestion.
1988 YX600 Radian
