Author Topic: PFH's on a loop  (Read 1672 times)
Offline cwiseman
    • C&D Motorsports
PFH's on a loop
« on: August 19, 2016, 07:34:57 PM »
Anyone have experience fitting Ducati clamp style PFH Dellorto's to a loop frame.
My old Eldo is going to be able use bigger carbs due to engine work. I've read on this old tractor about going with the non clamp style carbs and that is not anything I want to mess with.
Other option would be to find a good used set of VHB30-32's
Appreciate any guidence ya'll might have
« Last Edit: August 20, 2016, 12:53:37 AM by cwiseman »
618-544-RIDE
Offline guzzista
Re: PFH's on a loop
« Reply #1 on: August 19, 2016, 08:38:06 PM »
VHB's  30's would be the straightest swap ( if you have  Amals  930's you will also need manifolds) . I have seen DUC bevel  clamp type both 30's and 32's PHF's on them . From what I know they should sleeve on the VHB manifolds. The plastic insulation sleeves inside  PHF's may need replacement ?  . George Dockrays V700 build was featuring PHF 36's on specially built manifolds, which  I believe other forum members also used
Re: PFH's on a loop
« Reply #2 on: August 19, 2016, 10:31:48 PM »
I have a pair of PHF30 carbs that came off a 850T. I have stripped and cleaned them in my ultrasonic cleaner, they are in good shape. PM me if interested.
Offline travelingbyguzzi
  • God hates a coward
Re: PFH's on a loop
« Reply #3 on: August 19, 2016, 10:43:30 PM »
I have occasionally wondered if there was Amy significant difference between vhb 29s and vhb30s. Other than the obvious 3%....
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
08 1200 Sport AKA:Sweet Leaf
Moto
Re: PFH's on a loop
« Reply #4 on: August 19, 2016, 11:08:34 PM »
Yes. The difference is 7%, not 3%, as it is the area of the throat that matters. That varies with the square of the ratio of the diameters. (30/29)^2 = 1.070.
That's evidently enough of a difference that Dellorto bothered to make the two sizes, and Guzzi decided to move up.
Re: PFH's on a loop
« Reply #5 on: August 20, 2016, 10:41:28 AM »
Ha! Right, you are! My math is pretty bad for a surveyor. Actually, it is not the math, it is the concept. Still, a fail on my part.
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
Online Cam3512
Re: PFH's on a loop
« Reply #6 on: August 20, 2016, 01:13:02 PM »
There's 3 kinds of people in this world.  Those that are good at math, and those that aren't.
Re: PFH's on a loop
« Reply #7 on: August 20, 2016, 03:03:08 PM »
In real-world "butt dyno" testing, I can't tell any difference whatsoever. <shrug>
