Author Topic: LEAKING FORK SEAL - '13 Stelvio  (Read 3213 times)
Offline Spuddy
« on: August 25, 2016, 10:54:04 AM »
Is this common under 10,000 miles? Is it difficult to replace the seal and wiper? What do I need to know before I tackle this myself?
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
Offline Phang
Re: LEAKING FORK SEAL - '13 Stelvio
« Reply #1 on: August 25, 2016, 11:46:53 AM »
one of the fork seals of my Griso started weeping at around 12,000 miles.
I bought the original seals, before I roll up my sleeve, I read about Sealmate.
I was skeptical at first but it cost almost nothing to buy one. So I bought one and MotionPro sent me two for the price of one.
It works  :thumb:
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline dlapierre
    • Habitat Farm
« Reply #2 on: August 25, 2016, 11:56:49 AM »
The process worked for me, too. But, instead of buying one, I experimented with a piece of plastic cut the same way. Not to sound too cheap, I jut wanted to see if the idea was sound. It was.
beetle
« Reply #3 on: August 25, 2016, 10:44:29 PM »
Me too. I made one from a plastic bottle. It stopped the leak for a few thousand km. Then when it leaked again, I changed the seals.
Offline ITSec
« Reply #4 on: August 26, 2016, 12:44:14 AM »
As has been noted, it's always worth a try to clean the seal first.
As for how long they last, that's sort of like asking how soon you'll get grit on the tube - because that's the usual cause for a leak and for seal damage. Sometimes they fail for other reasons, but that's the most frequent - especially if you use your Stelvio off pavement.
I has a fork seal go bad at about 17,000 miles on my Norge - cleaning didn't cure it, so I had it replaced with a third-party product. The bike now has 115,000 miles, and the fork seals are still good. I may replace them at my next major service, just as a preventive measure, since living in the Mojave combines a lot of sand and dust with a lot of heat and UV - all rubber killers.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline pmillar
« Reply #5 on: August 26, 2016, 12:40:56 PM »
Well, you obviously need to stop popping so many wheelies as rough landings can lead to blown seals.  :grin:  The cleaning suggestions are good as well as carefully looking at your forks for any nicks that might harm the seal.
Ann Arbor, MI
'73 Eldorado
'97 TL1000S
'00 TTR250
Offline Spuddy
« Reply #6 on: August 29, 2016, 11:12:11 AM »
Fuggles, I didn't think of that...
Spud
'13 Stelvio NTX
'01 W650
Offline Green1
« Reply #7 on: August 29, 2016, 09:23:14 PM »
I have used an old 35mm film negative to do that in the past,worked great
Never argue with an idiot, people watching can't tell the difference
« Reply #8 on: August 29, 2016, 09:25:29 PM »
Yeah....when you drop it down, the extra weight of the chair makes it hard for the oil to stay in.  Clean the tubes and refill with auto-trans seal treatment.  It should help till the end of the riding season.  Then you can work on it during winter.  You can use this seal puller without disassembling the fork.  Just remove the fork tube from the triple tree and remove the seal through the top of the fork.  Just make sure that there are no burrs on the whole tube.  I think I bought mine from Snap On or Carquest.
 http://www.sears.com/lisle-automotive-repair-tools-shaft-in-seal-puller/p-SPM2374492414?plpSellerId=USAetail&prdNo=4&blockNo=4&blockType=G
