1200 sport front wheel ( and tire)
Topic: 1200 sport front wheel ( and tire) (Read 1421 times)
onerne
New Egg
August 25, 2016, 07:51:16 PM »
I removed the front wheel to replace tire with Pirelli angel GT. I had local dealer source, mount and balance the new tire and when I installed it I noticed the valve stem was on the left vs. rear is on the right
(1) Is the front wheel reversible? I could see nothing to indicate otherwise
(2) Dealer said GT is compatible with the ST I have on the rear. Anyone have an opinion or experience with this combo?
Robert Eberly
Mt. Crawford, Va.
79 sp
08 1200 sport
72 trail 90
Idontwantapickle
The rotation of the earth really makes my day.
Re: 1200 sport front wheel ( and tire)
Reply #1 on:
August 25, 2016, 08:07:59 PM »
You wouldn't want to reverse your brake disks unless you replaced the pads. The Norge wheel is marked for direction, and the ABS sensor wheel must be on the right.
I always mark wheels when I take them for tires just so the shop doesn't have to puzzle over it.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Bisbonian
Living the Dream
Reply #2 on:
August 25, 2016, 08:39:23 PM »
The wheel is somewhat directional as in the spokes don't come straight out but are angled off center.
It would bug me, and I'd have them make it right if it's really backwards.
It's possible they removed the valve stem to put in a fresh oring and didn't pay attention to the direction it was pointing.
willowstreetguzziguy
Reply #3 on:
August 25, 2016, 08:43:47 PM »
The raised lettering on each spoke (Moto Guzzi etc.) is only on one side and faces the right side on my '08 1200 Sport, opposite the sidestand.
2008 Guzzi 1200 Sport
1993 BMW K75S Pearl White (sold)
"Going somewhere isn't why you ride, riding is why you go!" Moto Guzzi... because the only person I have to impress is me.
Reply #4 on:
August 25, 2016, 08:57:36 PM »
You're saying the tire is on correctly but the wheel may be on backwards? Did you mark it for the shop installing the tire? Bummer. Could move the brake pads around?
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
onerne
New Egg
Reply #5 on:
August 26, 2016, 08:27:42 AM »
thanks for all the replies, I will check lettering on spokes and if reversed I'll chalk it up as another learning experience and have tire remounted.
Robert Eberly
Mt. Crawford, Va.
79 sp
08 1200 sport
72 trail 90
Kiwi Dave
Reply #6 on:
August 26, 2016, 08:27:56 PM »
I'm fairly sure it isn't possible to mount the wheel on backwards. The spacer sits in the LHS of the wheel center, while the axle bolts up against the right hand side.
I'm not going to pull mine off to check this, but next time I remove it for a new tire, I'll try to remember to deliberately try to assemble backwards.
Reply #7 on:
August 26, 2016, 08:58:54 PM »
Field research results pending.......
