Author Topic: Safety wire and lug bolts  (Read 1041 times)
Offline atavar
« on: August 28, 2016, 03:00:41 PM »
So having removed the rear wheel from the Norge the lug bolts are drilled for wire.  There was no wire on them when I took the wheel off.  As I think about it these are a covered up never checked single point of failure item that could hurt a guy badly.  I am thinking I will wire them just because it can't hurt and just maybe might help.
What do you guys think?  Do any of you wire safety items like this?
Online RinkRat II
  • Lake Powell AZ
Re: Safety wire and lug bolts
« Reply #1 on: August 28, 2016, 03:12:12 PM »
Unless you run in a sanctioned event that requires it ,probably not necessary except for peace of mind. I don't believe those were drilled from the factory. Proper torque is your friend :bike-037:
   Paul B :boozing:
Offline pete mcgee
« Reply #2 on: August 28, 2016, 04:01:56 PM »
Lock wire is a backup to correct torque, and as a last line of defence.
As in your case it will not take a lot of effort or time and will give you peace of mind, go for it.
Post photos of the finished result so all the ex and current aircraft mechanics can "critique"  :popcorn:
Cheers
