Author Topic: Tire inspection reminder  (Read 7876 times)
Offline tonUPRacer
    • My Racer FB page
« on: August 30, 2016, 11:16:50 AM »
Did a little tire inspection this morning and found this. New tire ordered.
 Glad I found it now rather than "experience it" later.
2013 V7 Racer #393
2001 Ducati 900SS (sold)
1999 Ducati 900M (sold)
1979 HD XLS Sportster (sold)
Offline ITSec
Re: Tire inspection reminder
« Reply #1 on: August 30, 2016, 11:46:51 AM »
Fair bit of dry cracking in the sipe channels - good catch.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #2 on: August 30, 2016, 01:44:58 PM »
 YES , some real world tire advice . Thank you thank you thank you  :bow:
Offline oldlegs
« Reply #3 on: August 30, 2016, 04:26:45 PM »
Just got a reply from Pirelli for a very similar problem on the front of my V7 11 mine looks much worse and appears to be delaminating. Steve.
« Reply #4 on: August 30, 2016, 04:55:12 PM »
TonUPRacer, What make of tire?
« Last Edit: August 30, 2016, 04:55:40 PM by Tom »
« Reply #5 on: August 30, 2016, 05:05:44 PM »
I had some serious sidewall cracking on a couple Goodyear motor home tires and contacted them.  I started getting excuses like age, UV, ozone, so I asked "Is there a safety problem with continuing to use them?"   They immediately offered two new free tires if I paid for the installation.  I took them up on it.
I had a lifetime guaranteed muffler that rusted open.  I contacted the manufacturer, who told me I had to go to MD where I had originally bought it.  Again, I mentioned that it would take a while to get up there, and asked if it would there would be a safety problem to continue to drive until I could get the replacement.  And again, they immediately told me to get a new one locally and send them the receipt.  I did, and they paid me back.
I noticed a pattern... ask about the safety of continuing to use the product and they wake up fast.
« Last Edit: August 30, 2016, 05:06:18 PM by Triple Jim »
« Reply #6 on: August 30, 2016, 05:33:11 PM »
Good point Jim. :thumb:
Offline tonUPRacer
    • My Racer FB page
« Reply #7 on: August 31, 2016, 08:25:48 AM »
Tom, they are the OEM Pirelli Sport Demons. This is the original front, 3 years 9,200 miles so I'm satisfied with life. I didn't expect to see the type of wear (cracking/splitting) however. I replaced the rear last year at 7,500 miles. Overall I'm happy with the Pirellis and staying with them.
Andy
2013 V7 Racer #393
Offline Groover
    • Scooteropolis
« Reply #8 on: August 31, 2016, 09:44:07 AM »
I'll have to keep an eye on mine. Is there a batch number or some other marking to look for?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #9 on: August 31, 2016, 09:51:11 AM »
I wonder why your Sport Demon went twice as far as the one I had on the rear of my Mille.   It wore out at 3,800 miles.  I don't use a a lot of rear brake, and I'm not heavy on the throttle.
Offline ejs
« Reply #10 on: August 31, 2016, 10:46:51 AM »
Maybe you used the motorbraking alot??
California EV 1999
« Reply #11 on: August 31, 2016, 11:02:03 AM »
Good question, but I intentionally do not.
« Reply #12 on: August 31, 2016, 11:44:45 AM »
  Blowouts are natures way of reminding you to inspect your tires.
Offline pehayes
« Reply #13 on: August 31, 2016, 12:02:10 PM »
Is it possible there are some other dynamics at play here?
 :grin:
Offline SeanF
« Reply #14 on: August 31, 2016, 12:22:32 PM »
Tire pressures
Pavement quality
Oh, just noticed you mentioned you're talking about a Mille. So there's a not insignificant bike weight difference vs a modern smallblock.
I wore out the rear Sport Demon on my '14 v7 Special at around 4200 miles.
« Reply #15 on: August 31, 2016, 12:31:58 PM »
I'll say!  I can't believe you got 9200 miles out of a Sport Demon.  No wonder it was coming apart!
« Reply #16 on: August 31, 2016, 12:37:27 PM »
Yes, I think that's probably the reason, but 20% more weight causing 1/2 the life means the Mille must be over some critical load per contact area number or something like that.  I weigh 175 lbs, so I don't think it's all my fault.   :grin:
Offline SeanF
« Reply #17 on: August 31, 2016, 12:55:29 PM »
Fair enough on the motorcycle & rider weight diff.  :grin:
There's a horsepower difference too.
There may also be a difference in how one defines "worn out"...some say the wear bars, others may go until the cords start peeking through the carcass. I am more on the "wear bars" end of the spectrum.
Offline atavar
« Reply #18 on: August 31, 2016, 01:09:44 PM »
I just took the rear off my Norge and ordered the replacement.  With the PR4's there is a magic dark clean line about as thick as a pencil line that shows up in the center of the tread moments before it wears through to core so when I saw that I figured it was time.  I figure it is the last hundredth of an inch of rubber that for some reason cleans itself.
« Reply #19 on: August 31, 2016, 02:46:02 PM »
Andy.....I suspect the age of the tire plus where you live has a lot to do with the "problem" with your front tire.  The range of low to high temp. wouldn't have a positive affect on your tires with that age.
Offline oldlegs
« Reply #20 on: August 31, 2016, 02:51:48 PM »
TonUPRacer's tyre is a front yours is a rear would explain millage difference
« Reply #21 on: August 31, 2016, 03:09:25 PM »
Thats a good idea! Different colors for marketing.
Colored cords for safety. :thumb:
Offline tonUPRacer
    • My Racer FB page
« Reply #22 on: August 31, 2016, 03:28:20 PM »
My intent on the post wasn't to get input on why my tire was failing, I know why, it's old and has reached its limit on miles. I replaced the rear last year, because I monitor the wear. The purpose was to remind folks to check their tires. I knew I was going to have to replace the front this year, it was just a matter of time, and now the time has come. :thumb:
2013 V7 Racer #393
« Reply #23 on: August 31, 2016, 03:30:42 PM »
I was referring to his rear tire, which he said he replaced at 7,500 miles, about double what I got from my rear.
Offline atavar
« Reply #24 on: August 31, 2016, 03:32:48 PM »
If I got 7500 from a rear I would be doing a happy dance..  but that's on me and my binary throttle control..  lol :bike-037:
Offline tonUPRacer
    • My Racer FB page
« Reply #25 on: August 31, 2016, 03:49:48 PM »
I also weigh in at 130lbs which is partly why I get longer life than most.
2013 V7 Racer #393
« Reply #26 on: August 31, 2016, 05:41:47 PM »
Age is probably the main factor but the range of temp.  Probably exacerbated it.  Good that you caught it.  Same age tire in the Phoenix area would not have the separation of belts.
Offline sib
« Reply #27 on: August 31, 2016, 05:48:16 PM »
I changed the rear Sport Demon on my V7II at 8100 mi and the front one at 10,100 mi.  I think that both could have gone a few hundred more mi before the treads would be gone.  For the record, I weigh about 190 lb starkers, figure another 10-15 lbs with full gear on, and my luggage and racks probably weigh another 20 lb or so.  I don't ride particularly fast, but not particularly slowly, either.  My unscientific hypothesis is that tire longevity is correlated with age (the rider's, not the tires'), and all that that implies.  I'm 74-ish.  YMMV!
« Last Edit: August 31, 2016, 05:49:47 PM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
« Reply #28 on: September 01, 2016, 04:00:04 AM »
Another point of reference.
I was at cords on the Sport Demon Rear by 6000 miles, but I recently replaced the front early at 12000 miles because of an then upcoming track day. I suspect it had another 1-2k in it.
Changed to Michelin Pilot Activs. Currently have almost 7k on the rear and hope for a couple thousand more. Front is new so should have it a couple of years.
Was VERY happy with their on-track performance, despite there being 6k on the rear at the time. The Demons were stickier and even more confidence inspiring, but the Activs have done everything I've asked right up to the very edges of the tire
Offline Groover
    • Scooteropolis
« Reply #29 on: September 01, 2016, 07:24:50 AM »
Good info on the Michelin Pilot Activs.
1980 Vespa SI Moped
