Author Topic: Retorquing heads on LeMans III  (Read 3317 times)
Offline Vince in Milwaukee
« on: September 04, 2016, 11:28:31 AM »
There's a hex cap at the top (brass/copper?) that requires a 10mm allen head to remove.  What spec. does that get torqued to when I am done?  Thanks in advance.
Vince
Gone but not forgotten:
Online John A
Re: Retorquing heads on LeMans III
« Reply #1 on: September 04, 2016, 11:42:26 AM »
I just tighten it to common sense tight. its just a plug after all.
« Reply #2 on: September 04, 2016, 11:44:02 AM »
  :1: Just a plug .
Offline Stevex
« Reply #3 on: September 04, 2016, 11:53:37 AM »
Don't forget to ensure the plug has an o'ring fitted.
« Reply #4 on: September 04, 2016, 12:11:31 PM »
My thought exactly, but you just never know.
« Reply #5 on: September 04, 2016, 12:12:19 PM »
No o ring on this one.  The parts blow up shows a "sealing washer" and that's what I've got.
Offline sdcr
« Reply #6 on: September 04, 2016, 12:39:21 PM »
   When Charlie Mullendore rebuilt the heads on my LM 3, I'm pretty certain he said that it has an O ring under that cap. He'll probably clarify that shortly.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline Old Jock
« Reply #7 on: September 04, 2016, 12:39:56 PM »
My advice would be to make sure you coppa slip or moly paste the threads on that little sucker & don't horse it up.
Like the front spar that goes through the timing chest its one of these items that seizes solid over time
The seal ring is an O Ring as I recall, well it was on my LM 1000.
I don't know the material but if you cannot get the Guzzi part I'd use a Viton ring or the like to make sure it can stand the temperature
« Reply #8 on: September 04, 2016, 04:37:13 PM »
I'll be sure to stick a small dab of anti seize on it.  Thanks!
« Reply #9 on: September 07, 2016, 11:00:50 AM »
I stand corrected, you and SteveX are right on the above.  The original plug did have an o ring on it (as shown on the parts diagram what is hard as heck to see when it's a copy and your eyes are getting older).  My mechanic buddy replaced it 18 years ago with another plug from a different year Guzzi that used a copper washer.  I also posted this question on the MGNOC Face Book page.  I believe it was Charlie who verified the o ring originally being there.  My mechanic buddy felt the original o ring was prone to leaking after a while.
« Last Edit: September 07, 2016, 11:01:58 AM by Vince in Milwaukee »
Offline mtiberio
    • TiberioRacing
« Reply #10 on: September 07, 2016, 11:17:00 AM »
whatever you torque it to, rest assured it will take a whole bunch more to remove it. IDKW
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
