Walt.....you'll have to take the tire and tube off the rim. Just thought that I'd throw that in.
I found a photo that I could zoom in on.
Is that a Bassa, or did Guzzi do that plastichrome trim on other models as well ?
Ok, I had a chance to search for the set screw...Guess I don't know what I'm supposed to see. To me, all I see is the hex socket (rusted) but nothing else.What am I to look for? Starting to feel a bit dense here...
whatever you do, don't try naval jelly on your nipples.
What are these spoke things you speak of?
Part # 12.Tiny little thing run up the center and jammed into the spoke to lock it. You can likely unscrew the nipple with the lock screw in place, but you will have trouble putting it back without loosening it a bit.
