Author Topic: Oh Gawd ...... must I first type all my posts into Word?  (Read 3536 times)
« on: September 28, 2016, 05:48:06 PM »
I truly hate it when I sluff a keystroke, and blow away a post I've spent time composing.  The post probably meant more to me than those reading it, but what a pisser to blow away a post I've spent time composing, correcting, etc.  And it seems to be only a matter of hitting a couple of keys at the same time.  Can anything be done, aside from composing and editing in Word, then cutting and pasting the final version into WG  to prevent this from happening?
Sorry .... Its been a long day!
Bob
Re: Oh Gawd ...... must I first type all my posts into Word?
« Reply #1 on: September 28, 2016, 05:48:59 PM »
laptop or desktop computer?
« Reply #2 on: September 28, 2016, 05:50:01 PM »
Desktop.  I do worse on a laptop!
« Reply #3 on: September 28, 2016, 05:54:22 PM »
 Slow down Bob , we'll wait on ya  :laugh:
« Reply #4 on: September 28, 2016, 05:54:41 PM »
Using a text app is a good idea since it usually autosaves every couple minutes, IIRC (haven't used Windoze in 5+ years)...others with more smarts may chime in with configuration suggestions....you might try a quick response then go back and click on MODIFY which should give you more leeway for composing....HTH
Offline webmost
  • Safety Third
    • The Sotweed Factor
« Reply #5 on: September 28, 2016, 06:18:15 PM »
Try terse. Briefer's better.
« Last Edit: September 28, 2016, 06:18:54 PM by webmost »
Unmitigated risk aversion is the new Puritanism; complete with witch hunts funny outfits and humorless preachers thundering doom. The Deity is Safety; Satan is a Lawyer; but the object is the same: to suck the life out of life and tell you how to live it.
Offline Groover
    • Scooteropolis
« Reply #6 on: September 28, 2016, 06:27:31 PM »
I've done that too many times. That's why I only do one line replies now.. Maybe two if I'm feeling like taking a big risk  :grin:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #7 on: September 28, 2016, 06:39:06 PM »
You can left click and mouse over to highlight the text, right click, and hit "copy" occasionally, to put it into the buffer.  Later if you lose it, you can use the "paste" feature to put back what you copied.
« Last Edit: September 28, 2016, 06:39:58 PM by Triple Jim »
« Reply #8 on: September 28, 2016, 06:53:39 PM »
Depending on your browser and operating system, try "Edit->Undo", or control-Z (windows, Linux), command-Z if on a Mac.
« Reply #9 on: September 28, 2016, 06:55:50 PM »
Yes, another good suggestion.
« Reply #10 on: September 28, 2016, 08:49:00 PM »
Or the shortcut version.
On windows, just occasionally tap control-A and control-C. Then when things go bad, just start a new post and tap control-V to paste the saved data in.
Offline rboe
« Reply #11 on: September 28, 2016, 10:48:11 PM »
Click on the back arrow in the browser. For some errors it will recover all your work.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
« Reply #12 on: September 29, 2016, 07:10:37 AM »
If the errant keystroke or mouse click marked all, or a lot of your text, continued typing will replace that marked text with the new text.     Undo (Control-Z or Command-Z, depending on OS) will recover the lost text.   The back arrow on the browser will cause it to be lost forever, as that will take you to the previous page.
That said, if you accidentally click on a link elsewhere on the web page that takes you to a different page, the back arrow will take you back to the post page, but, your text may or may not still be there depending on your web browser..
« Reply #13 on: September 29, 2016, 05:12:34 PM »
Good suggestions!
Thanks,
Bob
