Author Topic: MPH contact for Aussies  (Read 2453 times)
« on: September 28, 2016, 06:18:46 PM »
I'm keen to do the MPH solution for my '07 Norge. Can someone tell me the contact details ?
Re: MPH contact for Aussies
« Reply #1 on: September 28, 2016, 06:21:18 PM »
Address: 16510 Park Row Dr, Houston, TX 77084
Phone: (281) 647-6557
Email: mike@mphcycles.com
« Reply #2 on: September 28, 2016, 06:28:47 PM »
Thank you very much. Huzo.
Offline PJPR01
« Reply #3 on: September 28, 2016, 06:35:17 PM »
What are you needing Huzo...I am just 10 miles from MPH here in Houston if you need any help on this end.
Are you looking for the Startus Interruptus item or something else?
Cheers,
Paul
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #4 on: September 28, 2016, 06:46:52 PM »
Cheers,
Paul
Thank you Paul, yes it's the startups interrupteus kit that I'd like, relayed or otherwise. Very much appreciated.
Offline PJPR01
« Reply #5 on: September 28, 2016, 11:27:25 PM »
Very good...I have a spare one in case MPH doesn't at the moment.  Let me know if are able to reach them and if not, I can put one in the mail for you.
Paul R
2008 Silver Norge
2002 V11 Scura
« Reply #6 on: September 28, 2016, 11:47:26 PM »
Thankyou, I will keep that as an option, very much appreciated. Huzo
Offline tris
« Reply #7 on: September 29, 2016, 08:00:53 AM »
They're easy to do yourself Huzo if you wish
Get male & female 4 way Sumitomo Lock Type .250 connectors see here http://www.cycleterminal.com/250-connectors.html#SC250
Three wires go straight through and the 4th (yellow IIRC) is replaced in the connector that plugs into the relay with a fused feed from the battery.
I did this before I found MPH did them and because I didn't want to cut the loom
You can use the existing yellow as an ignition controlled supply to trigger relay for ancillaries if you wish.
1993 TW125 "POS" - Resting
« Reply #8 on: September 29, 2016, 02:17:10 PM »
Thanks again to all who took an interest. I ended up just removing the yellow wire from the plug that goes to the relay, and sealed it off, tried the starter and no relay click so I knew it was the correct wire. Then ran a fused wire from the battery down to the plug and slid the new wire and terminal into the hole vacated by the yellow wire and all is good. Thank you all for your prompt offers and advice. Huzo.
