My bike is not charging. when running it is showing 12.2 volts - about the same as right before I started it.What is a quick way to test that the stator is working? There is a red and two yellow wires coming out.I want to determine if it is my wiring or the stator is bad. 1975 850Tthanks,
aftermarket speedo, no tach.it is a stripped café bike that I bought with a horrible wiring harness. lots of those cheap auto part store male/female spade connectors. Sometimes a connector splice 6" or 8" from another one for no reason other then I guess to not have to use 1 longer wire. But it ran when I got it and I assume that it charged, as it started and ran after a few rides.here is the diagram that I made up when I took it apart. I know it is a mess - it wasn't made for any other reason other then help me get it back together easier. the 1-12 on the left side is the speedo connectors. As of right now, it runs and starts as long as the battery is charged.
Like Wayne says, you still need the dash light working.
