Author Topic: Access to ECU for re-flash?  (Read 2087 times)
Offline hannibal smith
« on: October 10, 2016, 04:51:24 PM »
2009 V7 Classic-
How do you access/remove (whatever the process) the ECU for a re-flash?
Re: Access to ECU for re-flash?
« Reply #1 on: October 10, 2016, 05:46:36 PM »
Why remove it? Plug in Guzzidiag and do it on the bike. Probably plenty of map options available by now, it's just a 15M-RC.
Offline malik
« Reply #2 on: October 10, 2016, 05:47:53 PM »
Remove the seat. On the side opposite the battery and between the relays & the fuses there should be a black & green plug poked down into the guts. That connects with the cables (best from Lonelec) & hence to your laptop with Guzzidiag installed. There are other posts here with photos of the plug & lots on the use of Guzzidiag.
Mal
« Reply #3 on: October 10, 2016, 06:21:32 PM »
Disconnect batt 1st, ecu is under RH sidecover. Unplugs easily from harness, 4 screws hold it on.
« Reply #4 on: October 11, 2016, 07:51:58 AM »
THIS!!!
« Reply #5 on: October 11, 2016, 08:27:10 AM »
I won't argue the Guzzidiag method at all, but if the OP isn't comfortable doing it and wants to send it to someone to do it... GuzziSteve has him covered.
« Reply #6 on: October 11, 2016, 01:48:03 PM »
Yeah, Chuck, but if the op never mentions any of that, how is anyone supposed to know?
