Author Topic: One last ride with oil leak, or don't chance it; what would YOU do?  (Read 9766 times)
Offline brider
As it always seems to happen (some mechanical issue to consider before a long ride), I have a sudden opportunity to take a ride in awesome weather from CT to Maine this weekend, but....the Cal II has an oil leak in the left-cyl head feed line that has gotten a bit worse of late. It's been leaking for a good 5-10k miles, evidenced by the constant oil sheen on that side of the engine and carb. I never held this bike (engine cleanliness-wise) to the standards of a Honda, so I lived with it. But after starting anew with a clean engine after having recently put it the timing cover back on, I actually saw a drip where the line to the cylinder is crimped to the banjo at the top of the engine case, after a week or so of riding.
Now, after a 30-mi trip down the slab, I've pulled off and had oil drip onto the header and start smoking. This may have been a random drip; I made it home fine with no other issues, and there is no puddle on the garage floor, but the leak IS getting worse.
SO! Would YOU hop aboard and take a glorious 400-mi round-trip with this condition, or would you take the safe route, and leave it in the garage and drive the 12-yr old minivan?
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Re: One last ride with oil leak, or don't chance it; what would YOU do?
« Reply #1 on: October 14, 2016, 01:11:43 PM »
 Yes , just leave the keys to the minivan with someone who will perform a rescue .
Online Ncdan
« Reply #2 on: October 14, 2016, 01:38:45 PM »
Take a chance, Columbus did;)
Red Dog
« Reply #3 on: October 14, 2016, 01:38:55 PM »
In my younger days I was more adventorus (can't spell)  & would have gone but now well what the hey I'd go
« Reply #4 on: October 14, 2016, 01:43:15 PM »
 Not a good example , that poor bastage thought he had found India  :rolleyes:
Offline brider
« Reply #5 on: October 14, 2016, 03:23:54 PM »
HA! That's a good one! I vowed NEVER to call my wife again when the Guzzi broke down. I would rather walk the 200 miles back home. I think the decision hinges on whether or not I think the oil line is in danger of a catastrophic failure. I don't think it is.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #6 on: October 14, 2016, 03:33:33 PM »
Have you taken a close look to see exactly what's leaking?
Offline Scud
« Reply #7 on: October 14, 2016, 03:34:14 PM »
If it's a little leak, I'd probably go for it. Then the question is - what sort of stuff should you bring along to make sure you will not need the stuff you bring along?
1/2 quart of oil
Tools
Towels
Gasket maker/sealant
etc.
That being said - you also have to look at where the oil's going. If it's getting blown back onto the rear tire, I'd take the minivan.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Offline old as dirt 2
« Reply #8 on: October 14, 2016, 03:54:36 PM »
so you haven't cared in the last 5-10k, why start now. Run it. carry a qt to top off if needed.
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
Online PJPR01
« Reply #9 on: October 14, 2016, 03:56:35 PM »
Two scenarios:
1.  Spend 3 hours and fix it
OR
2.  Don't fix it...have an adventure and do a ride report with pics here to share!
Either way...it will be better than driving the mini-van!
 :thumb: :thumb:
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
« Reply #10 on: October 14, 2016, 04:02:29 PM »
Brider....sounds like an easy fix.  Did you try tightening up the bolt first?  It might be loose.  Take bolt out wipe all surfaces off including crush washers and reinstall with proper torque.  Clean off oil line and start engine to see if that was the leak or the line.
Offline normzone
« Reply #11 on: October 14, 2016, 04:23:40 PM »
While the advice to fix it is all good, and that's probably what I would do, here is a low effort alternative.
Take it to the car wash, spray off all the gunk, ride it home.
Take a look at what has leaked since you washed it. If it's not bad, stick a rag in there and go riding.
 :wink: :grin: :laugh:
« Reply #12 on: October 14, 2016, 04:40:44 PM »
It's been leaking for a while. You haven't bothered to fix it, (The oil lines, especially the now ancient originals are crappy.) and now ask others for advice? Why? So if you do go for a ride and the hose fails catastrophically, (A quite likely scenario, as stated the original crimped hoses are shite and yours are now decades old.) you can blame someone else?
Replace the damn hoses. Do it when the engine is cold and use new crush washers.
Or don't.
Your choice.
« Reply #13 on: October 14, 2016, 04:54:17 PM »
As advised.  Clean and locate exact leakage point.  Repair.  Doesn't involve a lot of time for the oil lines.  If oem oil lines, you're way overdue for an R/R.
Offline johnr
« Reply #14 on: October 14, 2016, 06:47:16 PM »
Trivia...
Delightful quip but I don't think he took too much of a chance. It is believed he was able to give the maps of Admiral Piri Reis  a good eyeballing before he left.
New Zealand
Offline johnr
« Reply #15 on: October 14, 2016, 06:50:33 PM »
Two scenarios:
1.  Spend 3 hours and fix it ....have an adventure and do a ride report with pics here to share!
OR
 :thumb: :thumb:
Fixed it for you.
New Zealand
Offline TOMB
« Reply #16 on: October 14, 2016, 07:19:36 PM »
If you were already on a trip and this happened what would do?
Then do it/that
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #17 on: October 14, 2016, 07:23:21 PM »
Trivia...
 So this Reis fella was confused also ??
Offline guzzitime
« Reply #18 on: October 14, 2016, 08:36:19 PM »
Maybe a little heat shrink wrap to tide you over? :bike-037:
Offline MariusD
« Reply #19 on: October 15, 2016, 12:39:47 AM »
What he said!
I mean... what's 400 miles? Like 2 tanks of gas on that bike?!
Dude.... Top off the oil and scoot on out...
And maybe bring a 1/2 quart if you're REALLY that worried.
There'll be plenty of cold nites to fix it when it's no longer riding season...
Offline v7john
    • The Racing Rhino
« Reply #20 on: October 15, 2016, 04:48:23 AM »
Just fix it.
I've had an oil feed pipe let go in the past. The oil is under pressure and squirted out when the line failed but, unlike you, I had no warning. It happened 3 miles short of the dealers I was visiting to buy a copy of Guzziology. They came and got me, cleaned the bike and fitted a new hose. I wouldn't have wanted this to happen on a wet, dark night out in the countryside.
1954 BSA M33 500cc.
Online John A
« Reply #21 on: October 15, 2016, 05:30:23 AM »
You would be wise to take Petes advise. Those old oil lines can be just pulled apart, they are junk. If you cannot go on the ride because you've neglected your machine, that's the price of neglect. When one of those lines pops off it will stop you.
Offline chuck peterson
« Reply #22 on: October 15, 2016, 07:33:02 AM »
Have I told you about the time my ancient line burst, north of Berlin, Me?
Three quarts pumped onto the rear everything, amazing I did not die in the corners...riding last in the group, no one could scream at me to stop.
Seized motor with no oil on the side of the road with eight gazillion black flies...friend road north 20 miles and found a hydraulic hose shop for bulldozers, jury rigged a new line, three quarts added and prayers
Drove it back to the campground in Twin Mt, NH, at 25 mph, rented a uhaul to get home
New rings, shell bearings, all gaskets, crocus cloth on the crank...ran like stink another 30k, oh and the proper expensive bullet proof oil line...
And a feeling I had let my best friend down....
Your choice, eh? Just thought I'd let you know what happened to me....sorry.
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #23 on: October 15, 2016, 07:36:39 AM »
This. Of course I'm an airplane mechanic, but I can't imagine *not* fixing something that will leave you standing by the side of the road when (not if) it fails. What's it take? An hour?  :rolleyes:
Let me mention again that the crimped fuel crossover lines are junk, too, and need to be replaced by dual banjos. Don't ask me how I know.
« Reply #24 on: October 15, 2016, 07:44:17 AM »
Does the junk classification also hold true for the oil lines on the CARC series bikes?
« Reply #25 on: October 15, 2016, 08:11:29 AM »
No.
Offline OlDogface
« Reply #26 on: October 15, 2016, 08:24:08 AM »
My vote goes to the "fix it now" side of the ledger.
2013 Moto Guzzi V7 Stone
For every fact there is an infinity of hypotheses.
ʉۥ Robert Pirsig
« Reply #27 on: October 15, 2016, 01:47:01 PM »
Order some aftermarket stainless steel lines from your favorite aftermarket supplier, and slap some JB Weld over that crimped fitting. May work, may not. Not, is not fun.
Offline Huzo
« Reply #28 on: October 15, 2016, 03:27:15 PM »
Your gunna fix it at some point which will take a certain amount of time so what's the difference when you spend the time ? You've spent half that time already discussing it. What Roper says is spot on (again). What will you do if it blows and you don't notice immediately, what is going to blow up ? (Ask Pete or similar), no on second thought, ask Pete now. It's like going to a ball with your beautiful wife and she needs a haircut, do you just take her and hope no one notices or just get the poor bugger the haircut...the fact that you're asking  means you know the answer, and you just won't enjoy the trip as much anyway, would you go for a ride with a permanently runny nose leaking into your helmet? Just bloody well fix it. Ps enjoy your ride....
Offline Huzo
« Reply #29 on: October 15, 2016, 03:35:40 PM »
This bloke and Roper nailed it, most of the rest is B S...
