Author Topic: Bleeding Stone  (Read 1153 times)
Offline OlDogface
Bleeding Stone
« on: October 16, 2016, 11:58:27 AM »
Fellow Geese:  Thank you. I was able to track down a thread that already dealt with my issue. But, I took some great pics so I thought I would share.
Here is the old thread that help me:  http://wildguzzi.com/forum/index.php?topic=73127.0
My obvious problem.....
Dry above the starter.....
Wet below the starter.....
Remove starter.....
Probable culprit....
That line goes down to the crankcase....
Remove line.....
While removing that I noted the remaining hose was quite loose down into the protective sleeve. I removed the protective sleeve and found the same issue as Sib:  the single use hose clamp wasn't actually clamping anything. I was able to remove it quite easily without breaking the clamp....
Check to ensure the factory installed the one way valve correctly (they did):
Flowchart....
So, I'm off to the parts store for three hose clamps now.
2013 Moto Guzzi V7 Stone
For every fact there is an infinity of hypotheses.
ʉۥ Robert Pirsig
