Author Topic: Advice requested: adjusting OEM V7 windscreen (part 8877724) rake angle  (Read 4042 times)
Offline sib
I installed this windscreen over the weekend on my '16 Stone.  Beautiful fit and finish.  It does a good job of keeping the wind off my chest.  There is a range of adjustment of the windscreen's rake angle.  I tried several and it didn't seem to make much difference in the position and intensity of the wind on my head at speed (~60 mph), at eye level.  Have any of you broken the secret code for adjusting this windscreen?  The installation instructions offer no advice.  Thanks in advance.  BTW, I'm about 5'-10", have average proportions, and use a normal-height OEM gel seat.
P.S.  I've learned that there was an earlier windscreen bearing the same number (8877724), with one-piece round profile bare metal or chrome plated brackets, for the Breva and Nevada models.  This post is about the newer windscreen with flat two-piece black brackets.  But, any advice about the rake angle that applies to the earlier windscreen would probably also apply to the later one.
« Last Edit: October 17, 2016, 09:11:31 PM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Online Ncdan
Re: Advice requested: adjusting OEM V7 windscreen (part 8877724) rake angle
« Reply #1 on: October 17, 2016, 06:53:41 PM »
From my experience as a 50 year ridder of numerous bikes with shields this is a summary of my experience. There is two ways to get a turbulence free ride on a motorcycle. Either look through the screen, which I prefer, or look a 2-3 inches over with a shield that flips the wind upward due THE the last couple inches turns upward. Now, that being said , you will have wind to come under the shield allowing the wind to hit ones face from underneath. The way to stop this is fork shields. A full fairing is the most efficient wind protection out there, I know, as I have had numerous bikes with both shield and fairing hope this helps. It it makes you feel any better I'm going through the same thing and trying to get lowers for my 07 Calvin. Looks like I'm going to have to fabricate or alter fork shields to fix the issue.
Offline pyoungbl
« Reply #2 on: October 18, 2016, 07:33:19 AM »
I don't think there is a universal solution to windshield rake angle.  It boils down to trial and error since what I find to be OK will probably not suit anyone else (I'm 5' 11").  On my '13 Special I ended up getting a 2" taller windscreen with a flip on the top.  Now I do not get much buffeting.  I'm not in dead still air, can still look over the windscreen and have reasonable protection from some rain and bugs.  Gustaffson (https://bikescreen.com/ )made my replacement windscscreen.
https://photos.smugmug.com/Motorcycles/13-V7-Special/i-xGjwRST/0/M/IMG_1006-M.jpg
Peter Y.
« Last Edit: October 18, 2016, 07:39:15 AM by pyoungbl »
'13 V7 Special (red/white)
Offline pikipiki
« Reply #3 on: October 18, 2016, 11:24:08 AM »
Peter Y.
looks good,
I dont know the exact reason why but the fact there is a reasonable sized gap between the head lamp and the botton of the screen helps create a smoother airflow with less buffetting
« Reply #4 on: October 18, 2016, 11:27:08 AM »
looks good,
 That gap allows for pressure equalization , the real secret to a buffet free zone .
Offline sturgeon
« Reply #5 on: October 18, 2016, 03:59:11 PM »
I use that shield on my 2014 V7S for touring (and a small Dart for otherwise). I normally set it such that the mounting bolts are at the bottoms of both sets of slots in the brackets, but I no longer remember exactly why. I'm sure I did some minimal testing when I first got it and came up with this setting from trial and error. I'm your height and use a stock seat (slightly modified but not for height). I do slouch a bit, which puts my head a bit lower. I try for minimal buffeting and don't care so much about clean wind hitting my helmet. I just wanted to reduce the wind blast on my chest on long cold days.
« Last Edit: October 18, 2016, 04:01:24 PM by sturgeon »
Dyslexics Untie!
11 Yamaha WR250R
14 Moto Guzzi V7S
16 BMW R1200R
Offline OlDogface
« Reply #6 on: October 18, 2016, 05:45:50 PM »
This thread comes at a good time. I am just looking for a windshield for my '13 Stone for light touring/cold. I like my bikes naked but I don't like being cold so I'm looking for something that can be installed/removed repeatedly.
pikipiki - I like the model you linked to but noted the manufacturer said that they only make the windscreens and drilling is required. Did yours come with mounting hardware? Any issues with fit?
2013 Moto Guzzi V7 Stone
For every fact there is an infinity of hypotheses.
ʉۥ Robert Pirsig
Offline pyoungbl
« Reply #7 on: October 19, 2016, 08:58:47 AM »
OldDogface, I ordered the Guzzi windscreen (which came with the brackets).  Although better than nothing the Guzzi screen was too short for my taste so I visited Gustaffson in St. Augustine, FL to have a taller screen made.  They used my Guzzi screen to make a form with the correct shape to fit the Guzzi brackets and drilled the holes as needed.  I watched the entire process.  Drilling the holes is no big deal.  You should use a special drill bit, which they can provide, to avoid cracking the plastic.  Then you use a Dremel type bit to enlarge the hole so the required rubber grommet will fit.  Pre drilled holes will not work reliably as motorcycle brackets seem to vary just a bit from bike to bike.  Bottom line, you need to supply the brackets and then mount the screen.  I do not think Guzzi sells the brackets as a stand alone part.
enlarging the holes so the grommets will fit.
Peter Y.
Offline OlDogface
« Reply #8 on: October 19, 2016, 07:17:29 PM »
Thank you very much for that information pyongbl!
ʉۥ Robert Pirsig
guzzipete
« Reply #9 on: October 19, 2016, 09:16:49 PM »
You might want to consider this: Wunderlich VarioERGO screen deflector
http://www.wunderlichamerica.com/mm5/merchant.mvc?Store_Code=WA&Screen=PROD&Product_Code=8110024-025
I have it installed on my R1200R and it works great.
