The motor won't crank with the side stand down, so don't see how it could be that switch.
Open the fuel cap. Do you hear the normal fuel pump startup process when you turn the key on. If the hose is off you can still hear pump noise.Check the video.https://www.youtube.com/watch?v=QFl4ZNUivpgPretty lengthy discussion along these same lines a few years back on this site.http://wildguzzi.com/forum/index.php?topic=49882.30
I believe you can check injector function with GuzziDiag.
Is it true that you can check fuel injectors with GuzziDiag? It was my understanding that this software was only good for dicking around with the fuel map.
Anyone with a Griso Is there any indication on the dash when the stand is deployed?
I haven't checked to see if the fuel filter has blown off. Would that block the fuel totally?
Yes, it is a blindingly bright orange light
Sounds like the side stand switch may still be the culprit given the way you've described it...have they tried starting the bike with the side stand up? Seems awfully coincidental the timing of it.
Just going off my experience with the California and the Calvin...they will both crank but not fire up with the side stand down...figured it's worth a check for the Griso too...
can you by pass it as a test ? I mean whatever the switch does when functioning correctly, just simulate that. Either bridge it, or disconnect it, there's only two ways it can be.
Two months ago, I changed the side stand switch on my 2007 Griso. I was test riding it, when the motor just shut off. The engine would crank, but wouldn't start. After sitting for months in the shop, the owner said that he could get the fuel injectors to open if they were connected directly to the battery but not otherwise. He has given up and says it needs to go to a dealer. He thinks he needs diagnostic equipment available only at a dealer. The closest dealer to me is about 150 miles from me (Memphis, TN)Any one got an alternative to an expensive trip? Anyone want to buy a used 2007Griso, with 59K miles on her?
