Author Topic: 2013 V7 Stone Speedo not functioning  (Read 2310 times)
Offline NorthfieldV11Sport
« on: October 21, 2016, 04:43:28 PM »
Any ideas?  So far I have cleaned up the plug and socket in the instrument cluster and no luck.  Is the sender the likely culprit?
Offline pyoungbl
Re: 2013 V7 Stone Speedo not functioning
« Reply #1 on: October 21, 2016, 06:17:09 PM »
You don't have many parts that can go south...and you have checked 50% already.  I'd take a close look at the pickup and also see if the wire has been nicked.
Peter Y.
'13 V7 Special (red/white)
Offline davedel44
« Reply #2 on: October 24, 2016, 06:31:34 AM »
Clean sensor on left rear.  Points at back brake caliper.  Mine was dirty and caused speedo to peg at 140mph, even at stsndstill.
Dave
Galveston
« Last Edit: October 24, 2016, 11:18:34 AM by davedel44 »
Bambino- 2013 V7 Stone
« Reply #3 on: October 25, 2016, 04:55:38 PM »
Can the sensor be cleaned without removing the rear wheel?
Offline davedel44
« Reply #4 on: October 26, 2016, 11:18:16 AM »
Yes.
Look at the back tire.  Side with the caliper and rotor.  Just above the brake cable you will find another black cable follow it back.  There is a bracket that holds the sensor.  The black sensor points directly at the bolts that hold the rotor.  I cleaned the side that points at the rotor bolts with a rag and some paint thinner.  Did not take anything apart just cleaned.  5 minutes top.  Fixed my problem.  Apparently enough crud had built up to affect the speedo reading.
Hope this helps.
Dave
Galveston
« Reply #5 on: October 26, 2016, 12:04:35 PM »
It may also have just come unplugged where it joins the loom.
Offline sign216
« Reply #6 on: October 26, 2016, 04:58:57 PM »
The sensor cable often rubs against the shift linkage by the swing arm.  Check that, and tie the cable to a nearby bracket to prevent further wear.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
