Author Topic: 97 Cali Swingarm interchange?  (Read 2383 times)
Offline wirespokes
« on: October 24, 2016, 02:06:17 PM »
I've got a 97 Cali I'm considering 'sporterizing'. It's got the longer swingarm and wonder which bikes have the shorter one that will work on this bike? What should I look for?
Re: 97 Cali Swingarm interchange?
« Reply #1 on: October 24, 2016, 06:32:41 PM »
Here ya go---http://wildguzzi.com/forum/index.php?topic=47583.0
Offline wirespokes
« Reply #2 on: October 25, 2016, 12:20:09 AM »
That thread is about the Magni Tonti swing arms. What I'm looking for is just a stock short swingarm that will work on a 97 Cali. Which ones will interchange?
« Reply #3 on: October 25, 2016, 12:47:41 AM »
All the pre-cal2 disk brake swingarms will 'fit', meaning the unit will go between the frame lugs properly.  Whether or not your brake/brake lines, wheel, centerstand, shocks, fender, DRIVESHAFT, etc also fit are matters for speculation.  I know the driveshaft won't work and the wheel area might be too narrow for your rim/rubber.  IIRC, the long wheelbase centerstand has interference issues and the shock angle will be radically different.  The frame is 3" longer back there, so the fender and wheel will be on different centers.  There is probably more that I can't think of right now.
Hope this helps.
Offline steven c
« Reply #4 on: October 25, 2016, 08:24:22 AM »
 I thought of doing this to a Cal 2 I just sold, even got the short swing arm and drive shaft. Like Roadkyll said there is a lot more involved in just swapping it out. But nothing that can't be handled with a cut off wheel and a welder!
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #5 on: October 25, 2016, 09:12:58 AM »
get Guzziology, it's all detailed there in easy to compare charts.
