Author Topic: Quick review if UClear HBC200 instal/Nolan 104  (Read 1800 times)
« on: October 25, 2016, 01:16:47 AM »
We had a discussion in the summer about Bluetooth in the helmet, and I decided on the Uclear HBC200 internal headset with boomless mic.  I got it installed today, but not tested yet.  Here's how it went.
The internal padding needs to be removed to expose the foam cheek pieces.  There is a single screw in the collar of the helmet, at the rear.  Same allen size as the sacred screw.  remove that and the plastic collar pops out (tab and hole) bringing the inner lining with it.
There are three pop-out rivets in the cheekpieces that allow the entire lining to be swung out of the way.  It does not need to come loose at the brow.
The cheekpiece foam slides out.
The speaker/mic holes are already formed in the cheek foam, but they are slightly small for the pods and don't have relief for the microphone snouts.  I carved them large enough to hold the pods securely with a common knife.  No big deal.
With the pods pressed into their holes I routed the wires around the collar area and brought the usb connection out the oem cable hole, just behind the visor control.  I had to shave the hole a tiny bit for the usb plug to pass through.
Reassembly of the interior was literally a snap (ok --several snaps).  The entire operation took about half an hour.
The result is a clean install - cable as short and unnoticeable as possible, and the control unit is convenient to my left hand.  The control unit is the only indication there is a headset installed.  there is no visible mic and no visible speakers or wire.
I will try the unit tomorrow.  Cell service sucks here and I couldn't get a signal to try the mics.  Speakers seem good.
Offline Mr Revhead
Re: Quick review if UClear HBC200 instal/Nolan 104
« Reply #1 on: October 25, 2016, 01:36:23 AM »
I've also got this unit.
Barely used it though as the speakers won't fit my normal helmet without shaving some serious amounts of material away. My other helmet they fit. But I don't like that one much. As far as sound for phone use, yeah ok, for music not so good, not loud enough or clear enough.
But they also have an ear bud option which I think I'll try.
« Reply #2 on: October 25, 2016, 01:46:23 AM »
Yes, some helmets present a challenge.  This unit was made with the Nolan N-series in mind.  The carving is minor and I'm told is due to a design change in the ear buds (after the helmets were in production) that made them slightly larger.
I've only got the one ear, so this concept of stereo headset music is lost on me.  I just want to hear the gps and talk to the nice robot lady giving me directions.  Mostly I don't want to be eating a boom mic all trip or have to have the gps turned up to 11 so I (and everyone else for half a block) can hear the robot lady.  So I think this is the right choice for my needs.
« Reply #3 on: October 25, 2016, 06:07:12 AM »
I've had my UClear for almost 2 yrs now.  I love it.  Mine is plenty loud.
Key to install is positioning the speaker/mic.  The angles on the mic buds has to be really close to the same on both sides.
Like any other headset the speakers need to line up with your ears (or ear  :)  ), not where the pockets on the helmet are located.  Some of us have ears that are not the same on both sides.  One of mine is about 1/2" offset from the other which means carving out a bit more foam.  I also have largish ears so the pockets get made deeper.
« Reply #4 on: October 25, 2016, 11:33:25 AM »
I have big, floppy ears like a cartoon dog, and the Nolan likes to fold them down if I don't wear my doo rag.  I've been thinking about altering the inner liner to fit them better.
I'll have more to report after the road test.
Offline Markcarovilli
« Reply #5 on: October 27, 2016, 09:41:49 PM »
RK - do the road test yet?   Looking for your impressions.....
Mark
