Author Topic: exhaust for 650 lario engine  (Read 2347 times)
Offline pitts12driver
« on: October 26, 2016, 10:49:50 PM »
I apologize in advance for this completely naive question.  I'm rebuilding a Lario for a friend, and have sorted out all the mechanicals.  What I don't know is what exhaust will fit at the exhaust port besides the pipe specifically for this model, and how specific any other options are to displacement??  Can I use an exhaust from a modern V7?  Can I use an exhaust from a 500?  I don't want to use the stock Lario pipes if I don't have to. Thank you for any guidance.
Re: exhaust for 650 lario engine
« Reply #1 on: October 27, 2016, 01:44:29 AM »
Out of curiosity, what was your solution to the valve and springs problem?
Online Matteo
« Reply #2 on: October 27, 2016, 12:12:28 PM »
V50III with Lario exhaust system.
« Last Edit: October 27, 2016, 05:09:22 PM by Matteo Manfredi »
« Reply #3 on: October 27, 2016, 02:54:28 PM »
I like the black pipes on my Lario, I guess you are looking for more bling?
« Reply #4 on: October 27, 2016, 03:07:14 PM »
For clarification, you're asking about the header pipe to the exhaust cans/mufflers?
« Reply #5 on: October 27, 2016, 08:54:07 PM »
Actually, I'm looking for less bling.  Want to create a simple 2:1 that tucks under the oil pan.  So, yes, I'm interested in header portions I can work with/weld on - not the cans.  Thanks everyone for guidance.
« Reply #6 on: October 28, 2016, 08:24:25 AM »
Ok, I'll go get my calipers. Got a picture of that Pitts 12? I built a S1S..uhh..34 years ago.  :shocked:
« Reply #7 on: October 28, 2016, 09:28:39 AM »
 Checked the diameters, and the 500 exhaust will definitely not work. If you are going the full Monty with the exhaust, why not just buy some 1 1/2" tubing bends and fabricate your own exhaust?
When you say " have sorted out all the mechanicals. " just what did you do? We don't need another head destroyed..
Are there any stock Lario parts the owner is going to throw away?  :smiley:
« Reply #8 on: October 28, 2016, 01:05:19 PM »
I got the impression from post that he wanted switch out the exhaust system from the heads down.  New/different from the heads down to the mufflers.
« Reply #9 on: October 28, 2016, 02:01:56 PM »
Yeah, that's why I mentioned just fabricating a new exhaust.. Why cut up a perfectly good set of headers?
