Author Topic: Lug Wrench  (Read 8209 times)
Lug Wrench
« on: October 28, 2016, 12:15:27 AM »
I'm sure I'm not the only one faced with this dilemma, what tool to take on a trip in case you have to remove a wheel nut on the roadside, a regular wrench for a 27mm nut is huge, here's  what I did.
Measure the length of a flat with a compass
The flat just happens to be exactly the radius of the nuts circle.
So without moving the compass scribe a circle on a scrap of metal
The radius also happens to go exactly 6 times into the circumference.
So divide the circle up by 6
And carved a simple wrench of 1/8" Aluminum using a regular wood coping saw, elapsed time < 60 minutes.
I made it short as I can always find a rock to use as a hammer. The aluminum is plenty strong enough for this task and it takes up little room in the tool box.
« Last Edit: October 28, 2016, 12:44:03 AM by Kiwi_Roy »
Offline ridingron
Re: Lug Wrench
« Reply #1 on: October 28, 2016, 12:23:25 AM »
And then?
Re: Lug Wrench
« Reply #2 on: October 28, 2016, 12:24:15 AM »
 So what did you do then?  Cut yourself a wrench out of a scrap of steel?
Re: Lug Wrench
« Reply #3 on: October 28, 2016, 12:27:36 AM »
Just be patient, i'm going as fast as photobucket will jet me  :embarassed:
Offline Phang
Re: Lug Wrench
« Reply #4 on: October 28, 2016, 12:33:44 AM »
I think, knowing the radius of the nut won't tell you the size of the socket, need a little calculations  :grin:
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Re: Lug Wrench
« Reply #5 on: October 28, 2016, 12:38:10 AM »
 So then the answer is blue ?
Offline Phang
Re: Lug Wrench
« Reply #6 on: October 28, 2016, 12:45:16 AM »
depending on which scientific calculator you used  :laugh:
Re: Lug Wrench
« Reply #7 on: October 28, 2016, 12:49:43 AM »
No but no measuring stick was harmed in the process  :grin:
Just measure across the flats for the socket size.
Re: Lug Wrench
« Reply #8 on: October 28, 2016, 12:52:47 AM »
 Plugging the data into one calculator gave me the answer of Clarinet , but I'm pretty sure that isn't correct  :laugh:
Offline Phang
Re: Lug Wrench
« Reply #9 on: October 28, 2016, 12:55:57 AM »
Very clever way of drawing a perfect hexagon  :thumb:
Offline Phang
Re: Lug Wrench
« Reply #10 on: October 28, 2016, 12:57:40 AM »
it hasn't been moisturised for a year, I hope the wood didn't crack
Re: Lug Wrench
« Reply #11 on: October 28, 2016, 01:01:15 AM »
 I'm guessing this will confuse almost everyone else  :laugh:
Moto
Re: Lug Wrench
« Reply #12 on: October 28, 2016, 01:49:04 AM »
This is the best tip in ages! I am impressed by the geometric construction and by the use of a coping saw (!) to make a useful tool. I don't know which is more delightful.
Makes me proud to be a Wildguzzi member.
Moto
Offline tris
Re: Lug Wrench
« Reply #13 on: October 28, 2016, 03:51:05 AM »
Well Apotherm is a new word to me ..... Wildguzzi is so educational  :bow: :bow:
Posed with the same problem, I planned to go down the route of a monster 27AF combination spanner and an angle grinder to chop it to a suitable length and then use a suitable rock to "persuade" it
However I ultimately solved the problem by flogging the Cali and buying the Breva - but still have the giant combi spanner lying around as I didn't get as far as chopping it up :wink:
1993 TW125 "POS" - Resting
Offline Phang
Re: Lug Wrench
« Reply #14 on: October 28, 2016, 04:04:18 AM »
out of curiocity, I calculated the radius/side length of a 27mm nut.
It's 15.5884572681mm  :afro:
Re: Lug Wrench
« Reply #15 on: October 28, 2016, 08:13:07 AM »
I still have the factory wrenches for my T5.  One of them is a double box wrench.  One end is 27mm for the axles.  The other is 22mm for the dipstick and fill plugs.  It's about 7" long and seems to be well forged steel.  A bit rough but it works well.
Re: Lug Wrench
« Reply #16 on: October 28, 2016, 09:11:11 AM »
This ^^ The original Guzzi "dog bone" wrench is what I carry.
Moto
Re: Lug Wrench
« Reply #17 on: October 28, 2016, 09:12:40 AM »
You can see by inspection that the ratio of the apotherm to the side in this case is sqrt(3)/2, remembering the Pythagorean theorem, and you can find the numerical answer in your head if you know the square root of three, which is about 1.73.
To see this, consider the length labeled "side" to be 2 units. Then either of the right triangles in the shaded area has an hypotenuse of C = 2 units (the radius of the original circle) and another side A of 1 unit. Since A^2 + B^2 = C^2, the remaining side, B, the apotherm, is B = sqrt(C^2 - A^2) = sqrt(4 - 1) = sqrt(3) units. The ratio of the apotherm to the "side" in the diagram, then, is sqrt(3)/2, which you could calculate in your head as 1.73/2 = .865, on a good day. The calculator value is sqrt(3)/2 = .866025.
Phang's formula gives the same result, of course. (I never heard of an apotherm, either.)
But Roy's Euclidean construction, with no numerical calculations, takes the cake, since there is no need to know the size of the resulting wrench. Kudos.
Moto
Re: Lug Wrench
« Reply #18 on: October 28, 2016, 09:29:59 AM »
= (27/2) * [2/sqrt(3)] = 27/sqrt(3)
The general rule, then, is hex size = sqrt(3) times flat length.
:afro::afro:
Re: Lug Wrench
« Reply #19 on: October 28, 2016, 09:38:45 AM »
Wow,
I'd really like to see the how you made a center stand.
Offline Two Checks
Re: Lug Wrench
« Reply #20 on: October 28, 2016, 09:42:16 AM »
Phang's formula...wasn't he Phyliss Diller's husband?
1987 1000 SPII "Il Duce' II"
Offline Phang
Re: Lug Wrench
« Reply #21 on: October 28, 2016, 12:07:49 PM »
:afro::afro:
You are good   :bow:
Are you a maths teacher?
I tried the trigonometry approach earlier today but googled the above formula for polygons.
not sure if I got it right, left school many years ago.
« Last Edit: October 28, 2016, 12:52:03 PM by Phang »
Re: Lug Wrench
« Reply #22 on: October 28, 2016, 12:20:14 PM »
  This stuff is beyond my photoaprehension.
Moto
Re: Lug Wrench
« Reply #23 on: October 28, 2016, 01:58:22 PM »
You are good   :bow:
No, I'm a sociologist.
I know very little math, believe me. Thanks for your kind words.
Moto
P.S. Your trig formula is right.
« Last Edit: October 29, 2016, 08:04:22 AM by Moto »
Offline OlDogface
Re: Lug Wrench
« Reply #24 on: October 28, 2016, 03:23:32 PM »
I just laid the nut on a piece of steel and scratched its shape with a nail. Then drilled a hole near one inside edge and cut the rest out with a jigsaw.
2013 Moto Guzzi V7 Stone
For every fact there is an infinity of hypotheses.
ʉۥ Robert Pirsig
Re: Lug Wrench
« Reply #25 on: October 28, 2016, 03:26:01 PM »
Me too.   And I don't have to find a rock...
Re: Lug Wrench
« Reply #26 on: October 28, 2016, 04:24:15 PM »
No rock, but, sometimes I have to kick it with my boot  :)
And mine does not look as good as Charlie's  :)
« Last Edit: October 28, 2016, 04:26:40 PM by charlie b »
Re: Lug Wrench
« Reply #27 on: October 28, 2016, 07:03:45 PM »
That one is actually just a photo from eBay. Mine looks even better - bought it as part of a bunch of replated stuff from Mark Etheridge, so it looks new.
charlie b: since your's is for the T5, shouldn't it be 22 mm on one end and 24 mm on the other?
Re: Lug Wrench
« Reply #28 on: October 28, 2016, 08:48:49 PM »
Charlie,
Well, I have been wrong before so it may be 24  :) For some reason I remember it being 27.  Will have to look at it next time I have the tool box out.
Offline leafman60
Re: Lug Wrench
« Reply #29 on: October 29, 2016, 05:46:22 AM »
I really admire the innovative improvisation of the Original Poster. I am not raining on his parade. However, similar already-made motorcycle wrenches are out there for those who don't want to cope with a coping saw:
http://www.ebay.com/itm/RK-Closed-End-27-mm-Wrench-for-Motorcycle-Tool-/192011133290?hash=item2cb4c1616a:g:VrIAAOSw8w1X3btV&vxp=mtr
« Last Edit: October 29, 2016, 05:49:05 AM by leafman60 »
