Author Topic: Part numbers for pre 1991 calif cruisrers ring and pinion 6/32 ratio  (Read 2114 times)
Offline TOMB
Im looking for the part numbers for the ring and pinion that is for the optional gearing (for cruising around town).
In Guzziology the ref is in pg. 14-6 and indicates the tooth count of 6/32 for a ratio of 5.333
I have a lot of parts manuals but I cant find any part numbers for this application . Pinion end has 20 teeth and requires a
special coupling  (10 teeth  for driveshaft end and 20 teeth for the pinion end ) Im sure that this is low demand low need item
but any assistance will greatly welcomed.
Thanks in advance
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline TOMB
Re: Part numbers for pre 1991 calif cruisrers ring and pinion 6/32 ratio
« Reply #1 on: October 30, 2016, 02:32:09 PM »
I found a part number in a micro fiche 1735-4690 (ring and pinion ) can anyone please verify For 1987 Cal 111 .
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #2 on: October 30, 2016, 02:39:06 PM »
It is in LeMans II workshop Man on page 169 #17354690 same PN, I think it has the Convert/5sp coupler PN also but good luck finding one.
Offline TOMB
« Reply #3 on: October 30, 2016, 05:06:58 PM »
Thanks Steve could you also provide the part # for the coupler for the drivehaft
To pinion. It's 10 teeth on one end and 20 on the other end.
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #4 on: October 30, 2016, 06:32:21 PM »
OK, it says "to be mounted with double cardan joint #14328040 and sleeve #18327700"
Sorry, I was trying to fit a Centy wheel on a Tonti swingarm. It's real tight, I will have to remove the rear drive to change wheel and make a brakeplate.
Offline TOMB
« Reply #5 on: October 30, 2016, 07:51:34 PM »
Thank you
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
