Author Topic: Out side of Visor misting up  (Read 4313 times)
Offline tris
« on: November 01, 2016, 02:45:50 AM »
Morning all
I came to work on the bike today as the car is poorly
So its early dawn, cars have their lights on, its overcast, road is moist, mist/fog abounds and the tractors have been out and about dropping mud on the road - not the best motorcycling conditions.
The problem I had was the pinlock visor was perfect .... on the inside but I was forever wiping the outside as the moisture kept sticking to it.
What propriety or redneck (I believe that is a proper Americanism) products do you recommend to resolve this
Cheers
Tris
1993 TW125 "POS" - Resting
Offline Motu
Re: Out side of Visor misting up
« Reply #1 on: November 01, 2016, 04:01:48 AM »
Pledge.  But it doesn't really help with fog...wipe, wipe, wipe.
Online fotoguzzi
« Reply #2 on: November 01, 2016, 06:48:01 AM »
RainX
Offline Zoom Zoom
« Reply #3 on: November 01, 2016, 07:08:05 AM »
Rain X is great stuff, but there are some plastics you are not suppose to use it on. I have no idea if the helmet visor is one of them or not. Just verify before using.
beyond that, I have just used Plexus of something similar, like car wax. Seems to do OK. On the inside, I use these anti fog cloths that I get from my dealer. They are reusable and keep the inside clear. They come in a little pouch that fits easily in my jacket pocket.
Running into heavy fog, you may just have to deal with it, just like in your car.
John Henry
Offline Zoom Zoom
« Reply #5 on: November 01, 2016, 07:37:48 AM »
Son of a gun. I had no idea they made a formula for plastic. Thanks Charlie.
I remember when Rain X first hit the market. It was an infomercial type of product than many though was snake oil. Turned out to be great stuff.
John Henry
« Reply #6 on: November 01, 2016, 08:27:05 AM »
Car wax isn't bad on visors.  I love Rain-X on car windshields, so I may try some of the OK for plastic version on my visors.
lucydad2
« Reply #7 on: November 01, 2016, 12:09:08 PM »
pV = nRT
physics of fluids, pressure and temperature
too many Moles of H20
Offline Sheepdog
« Reply #8 on: November 01, 2016, 01:27:45 PM »
Some visors have coatings that react with the Rain-X and cloud up the surface (Scorpian helmets come to mind). I've not used the version for plastics, but plan to give it a try (Thanks, Charlie).
Offline Nic in Western NYS
« Reply #9 on: November 01, 2016, 01:34:22 PM »
Pro Honda Spray Cleaner and Polish - beads up the fog and then at speed turn head to remove droplets.
'04 Ducati ST4sABS
Offline Zoom Zoom
« Reply #10 on: November 01, 2016, 03:37:45 PM »
As an FYI, Honda changed their formula a few years ago now. The new isn't quite as good as the old.
You can still buy the original formula, but its called the "Origina  bike spirits spray cleaner and polish".
John Henry
Hymes Inc.
« Reply #11 on: November 01, 2016, 03:56:08 PM »
Shaving cream works on glass for fog.  No idea about plastic.
Offline Sheepdog
« Reply #12 on: November 01, 2016, 04:25:09 PM »
John Henry
It's a great cleaner for when you travel, also. Since it is aerosol, it doesn't leak in your saddlebag (as long as you replace the cap). It's also a good emergency bead lube in the event you have to remove/install a tire.
« Reply #13 on: November 01, 2016, 07:30:10 PM »
John Henry
You're welcome.
IIRC in the 'old' days the original Rain-X was made for airplane windshields (which were plexi)...at least that's where I got my first bottle of it, from the recommendation of a pilot.  Over the years things changed and now they have several products.
FWIW, I'd still test it on your visor to make sure you don't have a coating that is incompatible.
Online wirespokes
« Reply #14 on: November 01, 2016, 10:14:24 PM »
I think rain x is just wax in an alcohol base. Polishing my visor with Carnuba Wax seems to work just as well as anything else. But mist is the worst, just like fog. The droplets aren't large enough to overcome the surface tension so hang in there.
Offline tris
« Reply #15 on: November 02, 2016, 02:19:42 AM »
Todays ride in (car still poorly) was totally different. Bright and sparkling and the bikes dash showing a * and 3 deg C - which brings a whole new set of concerns!!!
Thanks for all the guidance everyone
Rain X appears to be favourite and I see that there's a product called "Raincoat" that appears similar. I'll check them both out when I go to the bike show at the NEC in a week or so
Cheerio
Offline stevet
« Reply #16 on: November 02, 2016, 06:12:20 AM »
Here's a thumb wiper.
http://www.aerostich.com/adjustable-visor-wipe.html
My Aerostich Roper gloves have a built-in wiper on the left thumb, works well for this mist problem, like I had 2 days ago.
Steve.
Steve T.
Twin Cities, MN
Feejer, '10 Yamaha FJR
-George Eastman.
