Input shaft holding tool
Topic: Input shaft holding tool (Read 3324 times)
Late to the party
Gaggle Mentor
1987 1000 SP2
November 07, 2016, 09:56:56 AM »
I've got a 2000 Quota with a sick gearbox. Does anyone in the lower forty eight have (a) the Moto Guzzi tool that holds the input shaft still, or (b) a workable suggestion on how to do that such the nut can be removed?
Thanks in advance.
Late to the Party... and getting later.
guzzisteve
"Just Ride It"
Re: Input shaft holding tool
Reply #1 on:
November 07, 2016, 10:25:08 AM »
I used to use a large angle iron wedged in the clutch hub against the outer case. Then I made one out of an old clutch plate, drilled out the center rivets and went to a blacksmith friend. He cooked up a handle & riveted it in place.
acogoff
Reply #2 on:
November 07, 2016, 10:44:16 AM »
Vise grip type of welder clamps with the jaws "tuned" to fit the hub teeth.
Marshall County Minnesota USA
Antietam Classic Cycle
Happily stuck in the past.
Reply #3 on:
November 07, 2016, 10:46:07 AM »
^^^ I made a tool out of an old clutch plate. If you want an old clutch plate center to make a tool with, let me know and I'll send you one.
Last Edit: November 07, 2016, 12:17:28 PM by Antietam Classic Cycle
pehayes
Reply #4 on:
November 07, 2016, 11:13:22 AM »
Might be good for you to report where you are located. Might be someone right down the street. If you don't put it in your account profile, then put it in your signature line. I have the tools and have loaned them in the San Francisco Bay Area.
pehayes
Reply #5 on:
November 07, 2016, 11:39:44 AM »
BTW, I see you have an SPII as do I.
Wayne Orwig
Reply #6 on:
November 07, 2016, 01:24:30 PM »
Old clutch plate with a bar welded to it for me also.
Last Edit: November 07, 2016, 01:25:14 PM by Wayne Orwig
Kiwi_Roy
Reply #7 on:
November 07, 2016, 03:11:49 PM »
Old clutch plate with a hole drilled near the circumference piece of strap to a flange bolt hole, under tension of course.
Bolt the gearbox to a length of lumber to hold it steady.
Last Edit: November 07, 2016, 03:20:23 PM by Kiwi_Roy
Scud
Reply #8 on:
November 07, 2016, 05:02:57 PM »
The old clutch plate solution... So obvious now that I see it. And so cheap.
1989 Moto Guzzi LeMans
2017 Husqvarna 701 Enduro
2017 Moto Guzzi Stelvio NTX
2020 Yamaha TW200
Testarossa
Reply #9 on:
November 07, 2016, 06:00:48 PM »
I use a small claw hammer as a sprag.
Gone: 59 Piper Comanche 250, 69 Harley/Aermacchi 350SS, 71 Honda CB500/4, 74 Laverda 750 SF2, 91 Suzuki VX800, 50cc two-stroke scoot, 83 XR350R
normzone
'72 Eldo - 1980 to 1990 - '99 Bassa 2014 - 2023
Reply #10 on:
November 07, 2016, 06:11:06 PM »
Thank you, [Testarossa], for the new word in my vocabulary:
sprag
spraɡ/
noun
noun: sprag; plural noun: sprags
1.
a simple brake on a vehicle, especially a stout stick or bar inserted between the spokes of a wheel to check its motion.
a one-way clutch that keeps a vehicle from rolling backwards.
2.
Mining
a prop used to support a roof, wall, or seam.
When I had my Eldo, I learned never to throw old parts away. The uses that get found...
Last Edit: November 07, 2016, 06:12:23 PM by normzone
Muzz
On the backside of the planet.
Reply #11 on:
November 08, 2016, 01:50:06 AM »
The old clutch plate worked for me (thanks be to Pete Roper who had an old one lying around).
Where would we be without W.G. and the fine people who frequent it?
Reply #12 on:
November 08, 2016, 04:03:51 PM »
Always good input.
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
Don G
Reply #13 on:
November 08, 2016, 04:12:54 PM »
I never bother with special holding tools, I just use a healthy 1/2" drive impact wrench and zap that sucker off. DonG
