Author Topic: One blue pipe one not  (Read 13074 times)
Offline SaskMick
« on: November 20, 2016, 04:29:01 PM »
Is this anything to be concerned about ?
Re: One blue pipe one not
« Reply #1 on: November 20, 2016, 04:40:11 PM »
what do the plugs look like? are your valves set and throttle bodies sync'd?
Nice looking bike otherwise!
Offline SaskMick
« Reply #2 on: November 20, 2016, 05:11:29 PM »
The plugs look a bit dark, like it's been running rich but they look identical.   The valves are non adjustable.  I don't know abut the throttle bodies being sync'd, all I know is that it's got fuel injection.
It's only done 3500 miles.
« Reply #3 on: November 20, 2016, 05:19:52 PM »
Oh Hydro motor, was the recall done?
look close at the crossover pipe between the headers, is there a crack on the blue side? has it spent a long time idling? if yes then TB balance could be way off..
you do know these bikes like to rev? you don't want to lug it like a Harley.. shift above 4k ..
I'd start with a check of TB sync.. easy to do w/a twin max or other vacuum tool..
many guys here know more than me, wait patiently.
« Last Edit: November 20, 2016, 05:22:30 PM by fotoguzzi »
« Reply #4 on: November 20, 2016, 05:23:58 PM »
the left side runs hotter on my EV.  Just because.
Offline SaskMick
« Reply #5 on: November 20, 2016, 05:29:12 PM »
Yes the recall has been done.  There is no crack on the blue side. I have no idea how long it has spent idling, I have only just bought it.    I discovered that it likes to rev  :grin:
What's a TB sync ?
Offline SaskMick
« Reply #6 on: November 20, 2016, 05:31:43 PM »
What do your pipes look like ?
« Reply #7 on: November 20, 2016, 05:42:37 PM »
What's a TB sync ?
the butterfly inside each throttle body needs to be set equally so they open at the same time and same amount.. when closed both should be fully closed.. is the throttle stop screw holding the left side slightly open? OR do the air bleed screws need to be adjusted..
this not the best example but can illustrate the mechanism.
https://www.youtube.com/watch?v=gVTiUqw8hew
Offline SaskMick
« Reply #8 on: November 20, 2016, 05:50:00 PM »
Thanks   :thumb:
« Reply #9 on: November 20, 2016, 05:52:46 PM »
The left one is a little but lighter. Just like it's running hotter.  I bought it that way with 20k miles, it has 60k on it now.
Offline SaskMick
« Reply #10 on: November 20, 2016, 06:52:30 PM »
Please post a picture.
« Reply #11 on: November 20, 2016, 07:00:58 PM »
I doubt that the difference would show up in a photo.  I couldn't make much of the photos here either.
Offline OlDogface
« Reply #12 on: November 20, 2016, 07:14:45 PM »
It's an air cooled bike. The breeze must have been from only one direction. Solution:  turn around and go the other way!
Laughing....no, seriously, get your fuel system synced by someone that knows what they are doing. What goes in must come out.
2013 Moto Guzzi V7 Stone
For every fact there is an infinity of hypotheses.
ʉۥ Robert Pirsig
Offline Dofin
« Reply #13 on: November 20, 2016, 10:38:34 PM »
My V7 (1TB) was doing the same thing, in my case the dealer removed my charcoal canister and sealed the return at the intake.  I think I over filled the tank and raw gas most likely soaked the  canister and the fuel went back into the engine.  The plugs were black and the engine started to run poorly.  Now if I over fill the tank I smell raw gas, guess I wont do that any more.
76' Yamaha RD400
76' Suzuki GT500
89' Honda PC800
15' Guzzi V7 Stone
Offline Mr Revhead
« Reply #14 on: November 21, 2016, 12:06:46 AM »
What is that fairing?
« Reply #15 on: November 21, 2016, 04:03:30 AM »
Looks pretty good to me. What are the firing intervals again.............. ..........
redrider
« Reply #16 on: November 21, 2016, 06:56:38 AM »
Looks like the one for a V11 Café Sport.
« Reply #17 on: November 21, 2016, 08:36:55 AM »
As Pete alludes, the left (S) cylinder "works" harder than the right.
Just the same, a good tuneup is in order. Start with adjusting the valves, TPS, throttle body sync in that order.
Offline SaskMick
« Reply #18 on: November 21, 2016, 09:01:04 AM »
It came from the factory with that fairing.
Offline unclepete
« Reply #19 on: November 21, 2016, 09:02:14 AM »
Could someone please explain how the left cylinder works harder than the right ?
On my T-3 the right pipe is purple/blue and the left amber/straw colored , so opposite of OP .
The bike has 137k miles on it , and I guess it happened sometime in its past .
I have had it since summer 2015 and a bit over 4k miles , so not much experience , but it has not changed .
I do remember the initial carburetor setting differed slightly from one side to the other on the air screw ; thought that was odd .
« Last Edit: November 21, 2016, 09:31:55 AM by unclepete »
Offline SaskMick
« Reply #20 on: November 21, 2016, 09:03:42 AM »
The valves are non adjustable as it's a hydro version, but I will get the rest looked at.
« Reply #21 on: November 21, 2016, 09:34:41 AM »
Could you please explain how the left cylinder works harder than the right ? snip
Because of the unequal 270/450 firing order, the left cylinder fires first, then the right. It's a subtle thing, but the left should run hotter than the right, all other things being equal.
« Reply #22 on: November 21, 2016, 09:37:12 AM »
the left side runs hotter on my EV.  Just because.  :smiley:
« Reply #23 on: November 21, 2016, 09:39:31 AM »
I think this means the right cylinder gets a bigger "push" from the left one while the left cylinder gets a smaller "push" from the right because of the amount of rotation from the crankshaft.
being non technical type, I am just kinda guessing here.
This is something that will knock folks out when you play Trivial Pursuit, Mechanic's Edition.  You can only learn that here on WG.  Educational and fun.
« Last Edit: November 21, 2016, 09:42:52 AM by LowRyter »
Offline SaskMick
« Reply #24 on: November 21, 2016, 12:14:22 PM »
Looks like it's not much to worry about then. Performance wise it's fine.
Offline normzone
« Reply #25 on: November 21, 2016, 01:10:33 PM »
In the service manual it recommends swapping the exhaust pipes side to side every 12,000 miles  :evil:
Offline RANDM
« Reply #26 on: November 21, 2016, 03:41:17 PM »
Send us photos of how you hook up the crossover sport.  :evil:
Rough Edge racing
« Reply #27 on: November 21, 2016, 03:55:32 PM »
  But each cylinder must still rotate 720 degrees between ignition firing.....
« Reply #28 on: November 22, 2016, 09:22:04 AM »
True.. but it's been a long time since Dis side fired when the S side comes up to fire again.
« Reply #29 on: November 22, 2016, 09:29:40 AM »
If my bike looked like that I would not be satisfied with these answers and would still be looking for a solution.
