Author Topic: Exhaust leaking water  (Read 6958 times)
Offline SaskMick
« on: November 26, 2016, 11:41:05 AM »
2003 California Titanium
My exhaust leaking water, is this normal ?
Another question.... Is it possible to kill whatever it is that stops me from starting the bike when it's in gear ?
Re: Exhaust leaking water
« Reply #1 on: November 26, 2016, 11:53:17 AM »
If you mean that it spits water droplets out the exit when when the engine is cold, yes, that's normal.
I'll let someone more familiar with that bike answer you about how to make it start in gear.
Offline SaskMick
« Reply #2 on: November 26, 2016, 12:04:51 PM »
Jim,     There is often a puddle of water underneath the bike when I park it.     It clear water but it tastes disgusting.
« Reply #3 on: November 26, 2016, 12:22:11 PM »
 Stop parking over puddles , and try pulling in the clutch lever .
« Reply #4 on: November 26, 2016, 12:32:56 PM »
That Cali has an 'Idiot Logic relay' i think. All the idiot switches go to it. Sidestand, nuetral, etc.. Jumper it and you are good to go.
If you ride it more than 10mi in a single bound it will be warmed up and not condense water in exhaust.
« Last Edit: November 26, 2016, 12:36:14 PM by guzzisteve »
« Reply #5 on: November 26, 2016, 12:42:19 PM »
 Stop tasting bike pee.
Offline SaskMick
« Reply #6 on: November 26, 2016, 12:47:27 PM »
The neutral light is useful.
That's what I needed to know. Thanks
« Reply #7 on: November 26, 2016, 01:09:03 PM »
Try it with a little scotch.....
All internal combustion engines are water factories. If you are ever going to start them, you need to ride long enough to get it to a hot enough temperature to cook off the water. If not, the water is going to do damage.
That model has a neutral / sidestand interlock. NO SWITCH ON THE CLUTCH LEVER. You can't take it out of neutral if the sidestand is out.
You can wire around it, but why? Just stop running the bike on the sidestand while in gear, which is a bad idea anyway.
« Reply #8 on: November 26, 2016, 02:32:54 PM »
Puddles? Sounds like your sidestand needs adjustment.  :laugh:
« Reply #9 on: November 26, 2016, 02:45:56 PM »
It is obvious that the radiator has a leak and that leak must be found quickly before you loose all your coolant. :wink:
The baby B has the feature that if you pull in the clutch the motor will fire up in gear. Great if you happen to stall it in slow traffic; trying to find neutral with a stalled motor in a line of traffic is not my idea of fun. It also has a sidestand switch, which I personally think is a great safety feature. I have had a sidestand spring break on a previous bike and it dug in two up when going around a corner at highway speed. Although we stayed up the right way it was frightening to say the least and I was pleased that there were no cars coming the other way.
If Steve's suggestion can be done while retaining the sidestand switch I would say do it.
Offline sib
« Reply #10 on: November 26, 2016, 03:09:52 PM »
It's elementary:  fuel + oxygen ---> energy + carbon dioxide + water
Yep, you don't want to disable your side stand switch unless you believe that both you and your bike are infallible.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline yogidozer
« Reply #11 on: November 26, 2016, 03:13:03 PM »
maybe it's not from the bike?  :rolleyes:
Offline sturgeon
« Reply #12 on: November 26, 2016, 03:25:43 PM »
Drinking water found on the ground is much like eating yellow snow.
Dyslexics Untie!
11 Yamaha WR250R
14 Moto Guzzi V7S
16 BMW R1200R
Offline SmithSwede
  • I don't want a pickle
« Reply #13 on: November 26, 2016, 03:28:56 PM »
Believe it or not, but burning one gallon of gasoline in an engine creates about a gallon of water.
That's why exhaust pipes rust.  And why engine oil can get contaminated by lack of sufficient heat.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
« Reply #14 on: November 26, 2016, 04:27:57 PM »
I liked not having a neutral (or sidestand) switch.
How else can you get though traffic with a broken clutch cable.  :)
« Reply #15 on: November 26, 2016, 05:13:49 PM »
All that crap just goes bad, bout as useful as the neutral light on a Convert(switch on the clutch cable).
Offline SaskMick
« Reply #16 on: November 26, 2016, 05:51:19 PM »
My Guzzi's leaked what looked like vanilla custard vape liquid :evil:
It's definitely water :laugh:    I saw it dripping from the exhaust.
I will get it good and hot tomorrow then leave it alone till spring.
Offline Dean Rose
    • Twin Valley Riders
« Reply #17 on: November 26, 2016, 07:14:10 PM »
Ride it in one gear lower than you usually do or just keep the RPMs up.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
« Reply #18 on: November 26, 2016, 07:16:42 PM »
Water.
Its everywhere!
Offline jbell
  • Some progress
« Reply #19 on: November 27, 2016, 05:18:53 PM »
Ummmmm, do you have a dog??    :sad:
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
« Reply #20 on: November 27, 2016, 08:50:02 PM »
Dean
 :1:  Loads of sins...from low rpm's.  Probably the main culprit to electrical "problem" with Bruce Springsteen's recent ride.
Offline Bulldog9
« Reply #21 on: November 27, 2016, 11:44:05 PM »
Condensation until the engine and pipes are hot enough to burn it off. Is very common. Best to ride it long enough that the system gets hot and it doesn't build up and sit very often, otherwise you will rust out your muffler bearings.
MGNOC#23231
« Reply #22 on: November 28, 2016, 12:00:21 AM »
 :1:
« Reply #23 on: November 28, 2016, 05:18:46 AM »
Raise the Sidestand before starting, or unplug the Sidestand Switch.
« Reply #24 on: November 28, 2016, 07:45:58 AM »
 :1:
Good God man,  where do you get this stuff??
Brilliant!
Offline sib
« Reply #25 on: November 28, 2016, 08:55:29 AM »
 :1:
That bearing must have come out of your broken wheelbase.
redrider
« Reply #26 on: November 28, 2016, 09:33:16 AM »
Have you noticed how the car exhausts emit fog on cold mornings after start up? Water in the exhaust. If those pesky intake valves would stay closed, the humid air is eliminated. (The bikes do the same)
MCN/ Dr. Barnes has a statement about electronic aids which I believe applies to safety switches: "these are systems designed to compensate for limitations in a rider's abilities...."
Offline sib
« Reply #27 on: November 28, 2016, 10:22:53 AM »
...MCN/ Dr. Barnes has a statement about electronic aids which I believe applies to safety switches: "these are systems designed to compensate for limitations in a rider's abilities...."
The same could be said of parachutes.
redrider
« Reply #28 on: November 28, 2016, 10:51:22 AM »
In the early 70's there was a huge uptick in sky diving and yours truly got on the train. I was also riding motorcycles then. The two endeavors are akin in my estimation. It is about risk management. Back then, some new fangled gizmos were coming out all in the name of safety. We know how bikes changed but did you know about the black box that would automatically deploy the reserve chute? Yep, there it was, attached to my reserve pack ready to save me from myself if I passed a preset altitude above a set velocity. I stopped using one when another chute jockey had his activate on the ride up.
Offline sib
« Reply #29 on: November 28, 2016, 01:03:36 PM »
I just crunched the numbers and you are right on the button.  Depending on the particular fuel blend, which has slightly different density, a gallon of gasoline produces between 0.98 and 1.07 gallon of water.
There's the solution to the western drought:  everyone burn lots of gas.
« Last Edit: November 28, 2016, 03:59:29 PM by sib »
