Author Topic: V9 "bypass" Oil Valve ??  (Read 2323 times)
Offline M0T0Geezer
    • The Ones I Rode
« on: December 25, 2016, 02:47:17 PM »
The Moto Guzzi USA site has this as part of the V9 Roamer discussion:
http://www.motoguzzi-us.com/motorcycles/v9-roamer.html
"The [crankcase] ventilation system reduces power loss due to pumping within the crank chambers and a new low flow oil pump that absorbs less power. The oil pump suction pipe is new as is the bypass valve."
Anyone here have a V9 Parts Manual with a diagram(s) of the ventilation circuit including bypass valve above?
I am wondering if the "bypass valve" is a possible replacement for the one used on the Breva 750.
'Geezer
Wisdom from the road:
Re: V9 "bypass" Oil Valve ??
« Reply #1 on: December 26, 2016, 12:22:59 PM »
I would imagine it is if there is room for it, but what would be the point of changing one out?
« Reply #2 on: December 26, 2016, 07:17:08 PM »
Its got an OPRV! Whoopy-Duck!
 :grin:
Offline Aaron D.
« Reply #3 on: December 27, 2016, 06:24:12 AM »
If you are racing a small block the lower pressure may give you a small boost-it's an illegal move in many production based classes, can't imagine it helping any Guzzi.
