The seat catch under the EV seat got damaged this summer. The glues that I tried, aren't good enough. And I'm not sure what kind of plastic it is.Would one of those plastic welders be a good idea? I've never even seen one used so I have no idea how good they are.
I repaired side cover tabs with super glue and baking soda. Sprinkle the soda on the wet glue on both pieces, then press together. It may break again but not at the repaired spot.
But I need to identify the material first I somehow.
I need things to keep me busy right now.
If this was ABS there are many solvent glues that will bond it. I use Tenax 7R available from many hobby shops on small jobs. For larger jobs straight methylene choride works.I would guess this plastic is delrin. Similar to nylon but stronger and more stable but just as resistant to solvents. Again on small items the soldering iron trick can work but the joint will not be strong as new.A plastic welder is probably your best bet assuming you can't just replace the part with new.
None of my normal solvents touched it. It is slick, like nylon or delrin.The soldering gun I used has a broad flat tip just for this type of job. But you have to manually trigger it constantly to control the temperature. I think I got the melted 'wire tie' to penetrate well. Time will tell.
Yes, I have repaired side covers with fiberglass, or super glue, and such with good results. I believe they are ABS.The EV seat pan appears to be nylon, or something similar. It is not touched by solvents like acetone, and glue does not stick. Thus the reason to think I may need to get it welded. But I need to identify the material first somehow.
If this was ABS there are many solvent glues that will bond it. I use Tenax 7R available from many hobby shops on small jobs. For larger jobs straight methylene choride works.I would guess this plastic is delrin. Similar to nylon but stronger and more stable but just as resistant to solvents. Again on small items the soldering iron trick can work but the joint will not be strong as new.A plastic welder is probably your best bet assuming you can't just replace the part with new.Pete
The seat base on my Breva is Polypropelene.
If the material is Delrin and you heat it over 420 degrees you will have no doubts as to whether it is Delrin or not. This material when over heated will cause your eyes to burn and your lungs will not be happy.
Cool. Polypropylene is apparently a weldable thermoplastic, which is good because there's no hope with solvents. How did you find out it's polypropylene? Is there a way to tell, like the smoke test someone mentioned above?
