Author Topic: v50 breather small catch can  (Read 3728 times)
Offline Moto Russki
« on: January 06, 2017, 08:49:22 AM »
Hi guys,
You have a great forum and I thoroughly read the other post on small block breathers. I've owned pieces of my v50 III for a while now. I'm building a custom bike with the engine. I know that depending on the condition of my engine internals, it may start to puke around 4k rpm. That's OK though, the bike will be purely off highway, low rpm use. The body is 2.5 inches tall. 2.5 inch diameter.
Do you think my small catch can design will hold most of the vapor oil?
Re: v50 breather small catch can
« Reply #1 on: January 06, 2017, 09:50:29 AM »
Should be, looks good. I used to use a V65TT collector that fits in the frame triangle by the headstock, plastic and not much bigger than that one you made. Looks good.
« Reply #2 on: January 06, 2017, 11:44:40 AM »
I'd think so..
Edit: If that is a small breather element I just saw in the sketch.. that will spray a really fine mist all over the engine and transmission.
Edit again:
Oh, Welcome to WG.. :smiley:
« Last Edit: January 06, 2017, 11:48:01 AM by Chuck in Indiana »
« Reply #3 on: January 06, 2017, 12:46:28 PM »
Looks good, I made mine out of pvc....
ditch the small filter on top and run a hose down to vent out the back or to the ground, even with the little filter it will mist oil all over your upper frame rails, coils, and under the tank....  Don't ask me how I know
Offline Clancy
« Reply #4 on: January 06, 2017, 02:44:24 PM »
I fitted this readily available aluminium one to my V7-II to keep the airbox clean (the outlet from it runs into the airbox).
It's only slightly larger than yours and seems to be working well.
upload image
Cheers
Craig
Offline waxi
« Reply #5 on: January 07, 2017, 02:51:36 AM »
Clancy, may I ask where did you get one? Looks very nice... :thumb: Can this be combined also with gearbox breather somehow?
Moto Guzzi Nevada, 1998
« Reply #6 on: January 07, 2017, 08:55:59 AM »
There are a lot of different sized catch cans on ebay for $20 or less.  Some have drains and sight glasses built in.
I made one from a small tomato paste can.  I drilled a hole for 1/8 pipe in the bottom at the edge, and another in the top 180* from the first.  Then I blew the tomato out like blowing an egg and added fittings. Oil comes in at the bottom and hopefully drains back through the same hole.  The top hole vents the system and has a hose on it going behind the wheel, just in case.
The tomato went into soup.
Offline Monza-jockey
  • Rainer Lang
« Reply #7 on: January 07, 2017, 11:36:37 AM »
My Monza had a soup can collector on it. Being steel it eventually rusted and leaked.
 I made one out of chrome plated brass; from sink drain pipe (GC). :afro: I sweat soldered 4,  1/4" brass barb connectors into it: 2 from the rocker covers, 1 return to sump, 1 atmospheric vent (the vent is positioned high). I capped both ends with brass sheet. The whole deal fits inside the left side cover next to the battery, with one hose down to the left. My thinking was that metal would help with condensing the vapor back to liquid. Even inside the cover, there's enough airflow to cool it. It's been holding up well for 25+ years. :bike-037:
I don't always ride motorcycles, when I do,  I prefer  Moto Guzzi.
Keep riding, my friends...
1982 V50 Monza
« Reply #8 on: January 07, 2017, 11:40:19 AM »
Attaboy.. :thumb:
