Author Topic: T3 Speedometer Question  (Read 1306 times)
Offline Fireflyr
« on: February 09, 2017, 07:04:27 PM »
I have a '77 T3 with a '75 instrument/dash installed.  The speedometer is way off, reads 100 mph when going 65 mph from what I remember.  Is there a difference in internal gearing between the two years or should they work?  The needle seems to jump around a lot too.  Any help would be appreciated and no, I don't have the T3 gauges.
1984 Lemans III
1977 T3
1974 Eldorado Police
MGNOC Member #23029
Offline unclepete
Re: T3 Speedometer Question
« Reply #1 on: February 09, 2017, 08:14:27 PM »
I have a '76 T-3 with a speedo that looks very much like yours .
When I first got it , the needle swung wildly and averaged a reading about 10 + mph fast .
I sent my instruments to member Wirespokes for cleaning and lubrication , and got them back reading with a steady needle and the speedometer calibrated very close . ( speedo indicates 70 at 67mph ) Cost was very reasonable .
When an instrument needle swings wildly , it is asking to be serviced . If you wait til something breaks , it will be much more expensive to remedy ]
[http://imgbb.com/]free picture hosting for ebay[/url]
The tach arrived reading about 2k . Turned it upside down and gave a light tap , and it stops on the peg .
« Last Edit: February 09, 2017, 08:24:20 PM by unclepete »
Offline Fireflyr
« Reply #2 on: February 09, 2017, 09:54:51 PM »
Thanks Unclepete, I sent him a PM.  I'd hate to break anything.
Pat
1984 Lemans III
1977 T3
MGNOC Member #23029
Offline wirespokes
« Reply #3 on: February 09, 2017, 11:51:43 PM »
I'm still learning the ins and outs of Guzzi gearing and how the speedometers relate to all that.
i'd maybe have you do a check involving counting the number of turns the speedo cable makes over a distance or 1/100th of a mile.
On second thought, I've worked on my own T3, so can double check and compare to yours. I'd assume your 77 would have the same gearing. And then I could determine if the T speedometer is geared right for your bike.
I also think Guzziology has that data.
Another question - does the odometer read correctly? Over a ten mile stretch, or even a 100 - is it accurate?
