Aprilia turn signals, compatible with Guzzi?
Topic: Aprilia turn signals, compatible with Guzzi? (Read 1742 times)
Flea
Hatchling
February 14, 2017, 04:45:24 PM »
Hi guys,
Had no idea that Guzzi turn signals run $35+ per unit! So got to searching high and low to see if there was a lower priced alternative...
Does anyone know if the Aprilia turn signal mounting 'foots' are the same as the Guzzi one's? From the photos on the net, they look about the same.
Would make for cheap alternatives.
Moto
Re: Aprilia turn signals, compatible with Guzzi?
Reply #1 on:
February 14, 2017, 05:49:09 PM »
Guzzis are not all the same. Which one are you asking about?
lucian
Reply #2 on:
February 14, 2017, 05:52:26 PM »
They will probably blink faster
leafman60
Reply #3 on:
February 14, 2017, 07:51:48 PM »
Those Aprilia signal stalks are common to many brands, including Triumph and BMW models (Aprilia used to produce the BMW 650 singles).
The price varies greatly depending on which source you buy from.
Here's the best deal I've seen- from AF1 Racing-
http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=57075
$5.99 for four.
Last Edit: February 14, 2017, 08:26:47 PM by leafman60
Flea
Hatchling
Reply #4 on:
February 14, 2017, 08:39:59 PM »
Quote from: Moto on February 14, 2017, 05:49:09 PM
Sorry! should've been more specific.
Guzzi v7 Stone
Reply #5 on:
February 14, 2017, 09:34:20 PM »
I fitted the Aprilia *Triangular* indicators to my Griso simply because I prefer the shape and they aren't chrome, (Or fake plastic chrome!). The only thing I had to do was remove the small locator 'Pegs' from the bases as they aren't required for the Guzzi.
