Author Topic: 8mm torque to destruction?  (Read 9268 times)
Offline guzziownr
« on: March 04, 2017, 07:00:44 AM »
I am almost ready to put the timeserts in the front cover of my Griso .  There are four 8mm SS bolts that are in there tight.  Penetrating oil has been applied and I am thinking of using my torque wrench to gradually increase the amount of force used to ensure I don't strip or otherwise destroy the fasteners.  How much would be too much?
« Last Edit: March 04, 2017, 07:45:10 AM by guzziownr »
Re: 8mm torque to destruction?
« Reply #1 on: March 04, 2017, 07:10:16 AM »
I am almost ready to put the timeserts in the front cover of my Griso .  There are four 8mm SA bolts that are in there tight.  Penetrating oil has been applied and I am thinking of using my torque wrench to gradually increase the amount of force used to ensure I don't strip or otherwise destroy the fasteners.  How much would be too much?
An I misreading you, or does that need re explaining ? The bolts are in there tight, and you want to increase torque ???
« Reply #2 on: March 04, 2017, 07:16:35 AM »
8mm used to be 22ftlbs, since 06' they got changed to 18ftlbs.
Offline guzziownr
« Reply #3 on: March 04, 2017, 07:44:01 AM »
Sorry Huzo, that was not clear.  I am removing the front cover to put it on the bench and put a timesert into the stripped front engine mount.
My torque wrench works both ways.  I can set it to see how much force I am applying to the fastener to avoid stripping it while removing.
Thanks to Guzzisteve for the correct spec.  It feels like more than 20 ft lbs by hand but I have been accused of insensitivity in the past.
« Last Edit: March 04, 2017, 07:47:29 AM by guzziownr »
« Reply #4 on: March 04, 2017, 07:48:31 AM »
Oh, ok now I see. You won't strip a thread by trying to undo an over tightened bolt but you may break off the head. Is localised warming an option ?
Offline guzziownr
« Reply #5 on: March 04, 2017, 08:26:25 AM »
I tried a bit of that yesterday with a heat gun.  There is a light snow outdoors right now.  The garage is around 50 degrees F.!  I will try a little more gentle persuasion.
« Reply #6 on: March 04, 2017, 08:52:46 AM »
Try to get the heat into the aluminium before the bolt gets too hot. The Al has a greater co efficient of expansion, so should allow easier rotation of the bolt. Good luck !
Offline acogoff
« Reply #7 on: March 04, 2017, 09:11:32 AM »
     A lot of differences in penetrating oils, some are worthless. Best is aerokroil fallowed by pb blaster. A steady torque while applying heat with a propane torch would be my choice though.
Marshall County Minnesota USA
Offline guzziownr
« Reply #8 on: March 04, 2017, 09:37:21 AM »
For some reason Kroil is had to find here in my (NY, Bear Mt.) area.  I will stop by AutoZone later today.
Huzo writes:  Try to get the heat into the aluminium before the bolt gets too hot. The Al has a greater co efficient of expansion, so should allow easier rotation of the bolt. Good luck !
Thanks, That block is a big heat sink!
My understanding of torque wrenches was faulty.  It works both ways but only measures torque one way.  Another clever plan ruined.
« Reply #9 on: March 04, 2017, 11:00:11 AM »
I have two words for you. Impact driver.
Offline SportsterDoc
« Reply #10 on: March 04, 2017, 11:09:17 AM »
If you do not have one, use a breaker bar, tap down on it (directly over the socket) while exerting CCW force.
Used to do that a lot removing JIS screws, but it helps with any fastener.
If that does not work, with moderate force, then have someone tap CCW on the breaker bar, in synch with taping down on the bar/socket.
23 V7-850 23 Yam XT250 18 Yam Bolt  22 Triumph St Twin  20 CanAm Ryker 14 Honda CB1100 18 Yam XT250 16 MG V7II 17 Yam TW200 12 Triumph Bonnie 02 Sportster 1200S 03 Sportster XLH883 76 Honda 750F 75 Honda CB360 70 Yam CT1 72 Yam CT2 72 Yam AT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda C11
« Reply #11 on: March 04, 2017, 11:12:49 AM »
When I lived in Flagstaff, mid nineties, my #2 daughter and husband stayed with us a few months.
Son-in-law did some work on his VW bus.
Tried getting axle nut (thirty something mm)  off with socket, breaker bar and cheater bar.
Did not budget with both of us jumping on it.
He then borrowed a stubby brass box wrench, only a few inches long, designed just for that nut, to be hit with a mallet.
Couple whacks and the nut was loose.
« Reply #12 on: March 04, 2017, 11:40:16 AM »
 :cool:
Offline guzziownr
« Reply #13 on: March 04, 2017, 01:09:37 PM »
I have used the tapping technique with good results in the past so that will be up next.  Blackcat is unfortunately in Florida so he is unable to give his usual encouragement (scowling and grunting)
« Reply #14 on: March 04, 2017, 02:52:51 PM »
Yeah, that's better than my plan. As an added precaution, I'd beg/ borrow/ steal or buy, a six sided good quality socket. If you round off the head, you're rooted.
« Reply #15 on: March 04, 2017, 03:15:38 PM »
All sockets in my tool boxes are 6 sided, except for some specific for 12 point heads.
Offline guzziownr
« Reply #16 on: March 04, 2017, 04:38:20 PM »
Currently watching youtube how-to
« Last Edit: March 04, 2017, 04:52:05 PM by guzziownr »
Offline v7john
    • The Racing Rhino
« Reply #17 on: March 04, 2017, 05:02:09 PM »
Sometimes just pouring a couple of kettles full of hot water over it will do the trick. Always worth a try.
1954 BSA M33 500cc.
Offline guzziownr
« Reply #18 on: March 04, 2017, 05:09:51 PM »
A non-destructive cure...
Offline Demar
« Reply #19 on: March 04, 2017, 05:18:47 PM »
Kroil can be found online.  https://websecure.cnchost.com/kanolabs.com/orders/order.shtml
It's my understanding that you should not use a torque wrench to remove bolts.
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
« Reply #20 on: March 04, 2017, 06:08:28 PM »
Offline guzziownr
« Reply #21 on: March 04, 2017, 06:20:19 PM »
Point 7 in this link:
http://www.norbar.com/en-us/News-Events/Blog/entryid/449/the-ten-things-you-should-know-about-your-torque-wrench
Max torque on my wrench is 120 lbs/ft so I don't think an 8 mm bolt is going to give it much trouble.  Any pointers on the impact driver?  Set it and whack it seems to be the short version.
« Reply #22 on: March 04, 2017, 06:27:11 PM »
I will bet Luigi used some form of lock tight (that will be white when you get them out) on those fasteners so heat should be your friend..
« Last Edit: March 04, 2017, 06:27:53 PM by fotoguzzi »
« Reply #23 on: March 04, 2017, 06:42:05 PM »
Yes, the V7 II service manual lists repeated use of Loctite 243.   May be the same for this application, unless bolted on dry.
But that is blue (not red) and is only moderate strength, which should remove "with hand tools"
However, if that does work, then 250 C is recommended.
https://dgs.oce.com/PrinterSupport/ProCut_Customer/MSDS/LOCTITE_243_MSDS_EN.pdf
« Last Edit: March 04, 2017, 06:43:23 PM by SportsterDoc »
Offline Murray
« Reply #24 on: March 04, 2017, 06:58:34 PM »
Make sure you twist it in the direction you want to go. Depending on how well its made they can have a habbit of changing direction between blows.
« Reply #25 on: March 04, 2017, 07:01:19 PM »
Hopefully Guzziownr will not be using a dead hammer on his torque wrench!
Offline Murray
« Reply #26 on: March 04, 2017, 07:31:02 PM »
I'll clarify make sure you twist it int he direction you want to go otherwise they tend to swap directions between blows.
« Reply #27 on: March 04, 2017, 07:34:58 PM »
^^^^^^ He's talking about the impact driver. It's easy to use.. hold torque on it with your hand in the direction you want it to go. (Normally, counterclockwise to remove a RH bolt) and smack it with your copper hammer. This serves two purposes.. it keeps the screwdriver/socket/allen wrench firmly bottomed out while giving the fastener a good jerk to break it free.
« Reply #28 on: March 04, 2017, 07:41:34 PM »
LOL...that'll teach me to pay more attention to the wording!
Kentktk
« Reply #29 on: March 04, 2017, 09:55:11 PM »
You will not find it at Autozone. You old guys need to realize that Google and Amazon are you friend
https://www.amazon.com/Kano-Aerokroil-Penetrating-aerosol-AEROKROIL/dp/B000F09CEA/ref=sr_1_2?s=automotive&ie=UTF8&qid=1488685963&sr=1-2&keywords=kroil+penetrating+oil
