Author Topic: How to weigh a bike......The weigh station is open, aw crap, closed for now.  (Read 10357 times)
Offline jbell
  • Some progress
I've seen to put front wheel on a scale and repeat with back wheel but I think you'd have to know the weight bias for the correct weight.  Would using two scales, one each for front and back and then roll the bike up on the two work or would all that weight on the edge of the scale bugger it up?  There are 440# scales on eBay for $30.
« Last Edit: March 22, 2017, 02:39:02 PM by jbell »
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Re: How to weigh a bike
« Reply #1 on: March 13, 2017, 06:38:35 PM »
Oh man, I'd like to have a buck for every time this one's been brought up. I could probably buy myself a new henway. :grin:
Offline Madtownguzzi
« Reply #2 on: March 13, 2017, 07:01:04 PM »
Stop by any truck stop with a Cat scale or when riding in the countryside most gravel pits, feed mills or scrap yard will have a scale. There is a farmers Coop a mile from my house that leaves their scale on 24/7. There are scales out there no need to buy your own.
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Offline screamday
« Reply #3 on: March 13, 2017, 07:02:47 PM »
Local landfill will have a scale also.
Sent from my SM-G900P using Tapatalk
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
« Reply #4 on: March 13, 2017, 07:05:20 PM »
An engineer member here says those scales at that weight won't be accurate. And Darren is pretty smart.
Offline leafman60
« Reply #5 on: March 13, 2017, 07:10:27 PM »
Weigh the front, weigh the back and add the two together.
Offline screamday
« Reply #6 on: March 13, 2017, 07:11:36 PM »
Makes sense.
Tony in SC
1988 R100RS
1998 V11 EV
Offline jbell
  • Some progress
« Reply #7 on: March 13, 2017, 07:16:51 PM »
I did a search before posting and very little showed up.  Being cheap, I'll weigh it one wheel at a time and add.
« Reply #8 on: March 13, 2017, 07:20:39 PM »
I "think" if you weigh 1 wheel at a time the other wheel should be elevated to the same height as the wheel on the scale is at so it's not tipped and loading the weight toward the lower wheel.
Offline wrbix
« Reply #9 on: March 13, 2017, 07:27:29 PM »
Now that's well reasoned.  :thumb:
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline jbell
  • Some progress
« Reply #10 on: March 13, 2017, 07:44:30 PM »
Yup, agreed.
« Reply #11 on: March 13, 2017, 08:03:24 PM »
Put bike on shoulders.
Climb on bathroom scales.
Note weight.
Take bike off shoulders.
Note weight.
Deduct weight 2 from weight 1.
Easy! :wink:
Offline Phang
« Reply #12 on: March 14, 2017, 02:26:42 AM »
Note weight.
Note weight.
Easy! :wink:
there is an easier way if you have a boat
some kid did that in 200AD
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline Waterbottle
« Reply #13 on: March 14, 2017, 03:01:10 AM »
Note weight.
Note weight.
Easy! :wink:
Your a cheeky bugger Muzz  :grin:
2015 Griso SE Rosso
2012 Stelvio 8V
2009 Griso R  Track only
76 GT 750 Suzuki
Offline waxi
« Reply #14 on: March 14, 2017, 03:32:51 AM »
Makes sense.
It does and it doesn't. I have once stepped on our local landfill scale, and it showed my weight accurate to kilogram (and they weigh 40 tons trucks).
« Last Edit: March 14, 2017, 03:35:56 AM by waxi »
Moto Guzzi Nevada, 1998
Offline Huzo
« Reply #15 on: March 14, 2017, 04:32:41 PM »
Yeah that's true, I drive what we call B Doubles here in Australia that can weigh up to 70 tonnes and I stood on the weigh bridge the other day and it got my weight within 1.5 kg. Although I wasn't happy with the number.
« Last Edit: March 14, 2017, 06:35:44 PM by Huzo »
Rough Edge racing
« Reply #16 on: March 14, 2017, 04:47:20 PM »
 The sum of each tire is accurate......Ever see cops using portable scales on a truck?  If you don't level it the weight will be off slightly...
« Reply #17 on: March 15, 2017, 06:35:20 PM »
  Muzz has the most accurate method.
Offline bassa99
« Reply #18 on: March 15, 2017, 08:01:27 PM »
Why not do it like Johnny Cash did to build  his Cadillac?   :boozing:
1999 Bassa
2001 Confederate Hellcat
1973 Norton Commando restoration project
« Reply #19 on: March 15, 2017, 08:11:15 PM »
if you had a level ramp on either side of a scale, just roll it over from one tire to the other.
Add up both, walla.   :thumb:
Offline twhitaker
« Reply #20 on: March 16, 2017, 04:33:32 PM »
Why couldn't you just put the center stand on the scale and balance it?
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline leafman60
« Reply #21 on: March 16, 2017, 05:40:38 PM »
Elevating the wheel not on the scale a couple of inches etc will have no significant effect on the weight reading when you add the two up.
Offline Darren Williams
  • Finally got me a Griso!
« Reply #22 on: March 16, 2017, 07:47:29 PM »
Commercial scales usually have to be annually calibrated and have the calibration certificate posted. Check the certs at your local scales to see at what accuracy they are calibrated.
The heavy load cells we buy to use on our material handling equipment are usually accurate within +/-2% of load in middle 60% of their range (with other factors compounding that accuracy level) and the lower range may be greater than a persons weight. One at each corner and the error can compound. Plus when you consider the load cells on those scales are ones with large ranges, a bike is going to be way down at the lower end of the scales range, well unless weighing a popular make of American bikes that is.
Offline KiwiKev
« Reply #23 on: March 17, 2017, 01:33:56 PM »
Note weight.
Note weight.
Easy! :wink:
Hey Muzz
Good advice , that's how I weigh our dogs. Mind you they only weigh between 4 and 6 kg's.
Online normzone
« Reply #24 on: March 17, 2017, 01:48:15 PM »
Just a caution, wheying your bike could affect it's appearance ...
http://www.ergo-log.com/acne-whey.html
Orange Guzzi
« Reply #25 on: March 17, 2017, 01:48:55 PM »
Measure the air pressure in the front tire and note.  Use two straight edges, one laid on each side to the tire contact patch parallel to each other.  Measure the distance between then and note.  Take the two straight edges, one laid in front of the tire contact patch and one behind the tire contact patch parallel to each other.  Measure the distance.  Multiply the tire patch width times the tire patch length times the tire pressure. This will give you the weight of that end of the bike.  Then do the same for the rear.  You will have the front and the rear weight.  Add them together for the total weight. This will get you very close.  I learned this on an afternoon kids show.  They Clown was teaching kids how to calculate the weight of an automobile.
Offline KiwiKev
« Reply #26 on: March 17, 2017, 07:45:49 PM »
 Reminds me of an old and very corny joke ..
How do you weigh a whale ?
Take it to a whaleweigh station .
Offline wirespokes
« Reply #27 on: March 17, 2017, 09:40:26 PM »
Because most bathroom scales don't go as high as 500 lbs.
Offline Huzo
« Reply #28 on: March 18, 2017, 12:00:03 PM »
Please let us off the hook now JBell. Were you joking from the get go ? Just put the front wheel on the scales with a piece of wood under the rear the same height, then the same for the rear. Add the two. THAT REALLY IS IT !!! If you stand on a set of scales on one foot you still weigh the same, just on both feet, each one takes half the weight, but you had me sucked in for ages as well...
« Reply #29 on: March 18, 2017, 09:10:01 PM »
Go out to your regional airport , find an FBO that gives pilot lessons for a private pilot certificate. Get to know a mechanic, preferably one that has an IA ( inspection authorization ) get him interested. In the old days and now some aircraft share engines. He should have calibrated load cells, the kind you can roll an aircraft onto. Hold the bike up, not influenceing it. And take your readings, front and rear. Hop on bike, have your assistant hold bike up, take your readings.Buy him some beer. Now you can calculate your c/g. Easiest way I know of.
