Author Topic: Triples Material - Cast Iron vs Aluminum  (Read 4039 times)
Offline Groover
    • Scooteropolis
« on: April 28, 2017, 08:15:42 AM »
Appears the older guzzi bikes, such as the Ambassador used cast iron triples. Newer stuff (mid 70's is newer I guess...) till today on most bikes (that I'm aware of), the triples are made of aluminum, with the exception from what I understand, the 85-ish Le Mans geometry update triples package which were also made of stamped steel for some reason.
Is there a benefit of one material over the other? Is it a cost savings type thing going with aluminum, or general performance (fit, flexibility range) type thing.
What do you guys think?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Triples Material - Cast Iron vs Aluminum
« Reply #1 on: April 28, 2017, 08:25:17 AM »
The "geometry update" kit and triples fitted to the '86 Le Mans was likely done in cast-iron/steel simply because it was the easiest to do, so a quick way to make them available. Maybe a little extra weight on the front end helped too.  :wink:
Offline Groover
    • Scooteropolis
« Reply #2 on: April 28, 2017, 08:28:11 AM »
I was wondering about the weight factor for that update as well, since I believe one of the improvements was also to use heaver bar end weights I think.
1980 Vespa SI Moped
Offline swooshdave
« Reply #3 on: April 28, 2017, 08:31:05 AM »
I have seen triple clamps made out of sheet metal so I'm not sure what the forces on those parts are. They just need to hold the forks and turn, right?  :laugh:
CB400 for example.
« Last Edit: April 28, 2017, 08:36:20 AM by swooshdave »
2001 V11 Sport
Offline mtiberio
    • TiberioRacing
« Reply #4 on: April 28, 2017, 08:31:22 AM »
yea, added inertial mass to dampen oscillations (tank slappers).
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Northern Bill
« Reply #5 on: April 28, 2017, 08:33:16 AM »
On a triple related topic.  I got an extra set of T3  triple clamps on ebay with the aim to cutting off the handlebar clamps and then grinding them smooth so they look like Le Mans triples.  Because they are aluminium, this would be pretty easy to do but do you think the integrity of the clamp might be affected?
1973 Triumph Adventurer Cafe Racer
1975 T3/Le Mans replica
1987 Honda CBX250 Track Bike
1989 Honda GB500
Offline swooshdave
« Reply #6 on: April 28, 2017, 08:37:00 AM »
You should probably be ok.
2001 V11 Sport
« Reply #7 on: April 28, 2017, 08:42:57 AM »
I wouldn't think it would hurt a thing..
« Reply #8 on: April 28, 2017, 08:58:55 AM »
Well, I'm pretty sure cast steel triple trees are still in wide use.  Usually on lower end models.
Aluminum is light, strong, and more expensive.  Plus, aluminum can look better, if shaped and finished nicely.
Offline Groover
    • Scooteropolis
« Reply #9 on: April 28, 2017, 11:03:49 AM »
Ok, thanks guys. The reason I ask is because I'm replacing the triples on a new project (1987 Le Mans 1000 SE) and I have a choice now to replace the damaged ones with either option since I was able to locate both types. Just trying to determine which set of triples would be best for this particular application since I plan on keeping the 16" front wheel.
I guess the real solution to this dilemma would be to have TWO Le mans project, then use the iron in one, aluminum in the other  :tongue:
« Last Edit: April 28, 2017, 11:58:07 AM by Groover »
1980 Vespa SI Moped
« Reply #10 on: April 28, 2017, 12:42:28 PM »
I would think that the triples being called "cast iron" are more than likely forged steel, or at least I'd hope that to be the case.
Offline Dukedesmo
« Reply #11 on: April 28, 2017, 12:48:47 PM »
Aluminium is used on modern bikes because it's lighter, some fancy race parts are magnesium as it's lighter still.
Le Mans II
Ducati 916
Ducati M900
« Reply #12 on: April 28, 2017, 01:26:43 PM »
As long as you stay with the "update"/'86 onwards triples, you'll be fine. I'm not sure I'd use the '85 triples with less offset.
Jay: they appeared to be cast (in sand) since the surface was rough and they looked quite crude. Forging would have resulted in a much smoother surface, no?
Rough Edge racing
« Reply #13 on: April 28, 2017, 01:32:30 PM »
 Yes forged or at the least, cast steel (malleable iron)  ...And they are yokes  :grin:
« Reply #14 on: April 28, 2017, 01:44:51 PM »
Yokes are what's inside an egg!  :grin:
Rough Edge racing
« Reply #15 on: April 28, 2017, 03:08:27 PM »
 then the triple trees must be Yolks.............. :grin:
« Last Edit: April 28, 2017, 03:08:42 PM by Rough Edge racing »
