Author Topic: 2010 California Vintage - fork dust seal removal  (Read 2716 times)
Offline QTreiber
« on: May 05, 2017, 09:19:26 PM »
Hello,
My 2010 California Vintage (~10,000 miles) has a leaky fork seal.  Before removing the fork I would like to try using a sealmate (http://sealmate.net/) to salvage the fork seal.
I tried to remove the dust seal to get good access to the fork seal but it would not move.
My bike has the type of dust seal shown in this tutorial:
http://motoguzzimaintenance.wikifoundry.com/page/Moto+Guzzi+Metal+Stone+Fork+Seal+Replacement
I am worried about damaging the dust seal or the fork leg.
Any hints would be much appreciated!
Offline Rich A
Re: 2010 California Vintage - fork dust seal removal
« Reply #1 on: May 06, 2017, 08:22:37 AM »
Did you remove the spring? I seem to recall that doing that made a difference, but I might be having memory issues.
Rich A
Online Ncdan
« Reply #2 on: May 06, 2017, 08:53:32 AM »
If the seal is leaking do yourself a favor and go ahead and replace the seals on both forks instead of chasing a problem that will continue sooner or late, sooner most likely. If there is fluid coming from the seal, it's a bad seal, period.
Just my humble opinion.
« Last Edit: May 06, 2017, 08:54:30 AM by Ncdan »
« Reply #3 on: May 06, 2017, 09:00:09 AM »
To get the dust seal up you must sneak a flat edge between the top of leg and dust cover & pry it up, then move around to opposite and do the same all the way around equally. It's a snug fit.
Online Perazzimx14
« Reply #4 on: May 06, 2017, 09:33:00 AM »
In my experience about 95% of the time the seal is not the problem but a speck of dirt holding the seal off the fork leg allowing oil to escape. This is why Seal Mates or a thing piece of plastic work so often. They clear out the obstruction and the seal lip can now rest against the fork leg effectively sealing the system. It is rare for a seal to be cut, torn or otherwise "breeched".
Most of the winter I rode my DR650 sidecar rig w/ no fork gaiters  and the seal started to leak pretty badly from all the dirt, dust, mud snow and ice. I had to do some fork maintenance so I ordered new seals. New seals came in and were the wrong size so I washed the old ones up with soap/water and reinstalled them along with some neoprene gaiters. Still leak free several hundred dirty, dusty, muddy miles later.  I was amazed at how much dirt was built up under the seal. It took some scrubbing to get it all clean.
Offline Phang
« Reply #5 on: May 06, 2017, 10:17:23 AM »
dust seal is interference fitted, a blunt screwdriver or hard plastic edge should be able to lift it if you work around the circumference patiently.
this picture should give you some idea what is underneath
2000 V11 Sport (Green)
1973 V7 Sport (Green)
