Author Topic: NGC 78 XL125 doesn't like to down shift  (Read 2679 times)
Offline steven c
« on: May 18, 2017, 11:43:47 AM »
 Most be a Honda person in this group. My 1978 Honda XL125 which had 377 miles on it when bought it with now almost 600! So really a 40 year old brand new bike. When it warms up the shifter acts like it is stuck will not budge unless i pull in the cultch for each down shift. I adjusted the cultch tp specs and also went to both extremes ,no play, lots of play, no difference, changed the oil three times, I'm thinking a clutch plate is sticking somehow. I was going to take a look at it but those wonderful Japanese screws will not budge, even with a impact screw killer. Any thoughts?
photo hosting ebay
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Re: NGC 78 XL125 doesn't like to down shift
« Reply #1 on: May 18, 2017, 05:14:25 PM »
Sorry? I don't really understand what you're saying the problem is? It won't downshift unless you pull in the clutch? Well while the gears are loaded it is going to be reluctant. Trying to crash it through isn't exactly wise.
If it's some other issue can you expand?
« Reply #2 on: May 18, 2017, 05:57:53 PM »
 What Pete said . Also , are you aware those Japanese screws are JIS and require a different bit ?
Offline Roebling3
« Reply #3 on: May 18, 2017, 07:14:18 PM »
All the above and possibly a warped disc, broken spring/s, misalignment. Can you change gears, up or down, during gear lash? As in engine running, bike rolling in gear, clutch engaged. Change throttle position quickly and gently to cause gear lash. Or: Something remote like rear brake dragging?  R3~
Offline steven c
« Reply #4 on: May 18, 2017, 07:28:33 PM »
 Up shifts fine. Let me try again, you come up to a stop sign, braking pull in cultch to down shift to first 5 to 4 to come to a stop,it will not,but not always, shifter does not move unless I pull in the cultch between each gear. I'm not stomping on the lever just normal foot tap.Sorry I'm not a good story teller.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #5 on: May 18, 2017, 08:11:34 PM »
So, if you hold the clutch in can you shift down all the way to N or 1st? or do you have to release/pull in clutch between each downshift?
« Reply #6 on: May 18, 2017, 08:21:57 PM »
 If I am understanding this correctly , that is normal behavior for those older Japanese transmissions . Try shifting down while still rolling , reverse of upshifting . Most of that gen trans won't let you skip more than one gear either direction , and not at all while sitting still . That is why you are needing to release the clutch between each gear .
Offline steven c
« Reply #7 on: May 18, 2017, 08:45:48 PM »
 Maybe that's just the way it is. I should have mention while stopped.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #8 on: May 18, 2017, 09:05:17 PM »
cute little bike!
« Reply #9 on: May 18, 2017, 09:10:28 PM »
 These are sequential gearboxes , that is the way they work .
Offline chuck peterson
« Reply #10 on: May 18, 2017, 09:26:59 PM »
I found out I can't roll to a stop in 4th or 5th gear on my Honda, have to downshift early and often to get to neutral at a stop...
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #11 on: May 18, 2017, 10:43:35 PM »
  So just use the clutch.  They did put it there for a reason I believe.
Offline steven c
« Reply #12 on: May 19, 2017, 06:50:01 AM »
Must be a Honda thing,I haven't owned one since 1980.
 Chuck are you and the Honda going to be at the Rossi Tiddler?
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline TOMB
« Reply #13 on: May 19, 2017, 10:54:42 AM »
You could get a Honda Vert
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline steven c
« Reply #14 on: May 19, 2017, 05:04:06 PM »
To shiftless for me.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #15 on: May 19, 2017, 08:28:20 PM »
Steven, by impact screwdriver I am assuming you are referring to the type you whack with a hammer and not a rattle gun?
On the 6 Hondas I have owned all screws have released with the hammer type.
Coming up to an intersection run right through the gears as you pull up. Never did stop in 4th or 5th and then try for neutral.
Offline steven c
« Reply #16 on: May 20, 2017, 07:00:12 AM »
 Back with a Hammer type. Lets say you made a quick stop in what ever gear you are in, you just can't snick down to get to first, you have to get rolling first. I have over 40 bikes in 40 years and never ran into this even my 72 F7 or 88 XT350 Maybe it is hard to explain because shifting is something I don't think about kind of like walking though I do trip once in a while!
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
« Reply #17 on: May 20, 2017, 07:39:27 AM »
If I stop the Rhonda in an upper gear, I have to downshift once, let the lever out a bit and it'll engage, then repeat till your down to first, all while your stopped and five soccer moms start honking at you...versus downshifting all the way to first while rolling to a stop
Planning on the 400f for the Tiddler Tour...see you this Sunday too?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
