Author Topic: Is my 04 raTi ready to blow up?  (Read 2404 times)
Offline ratguzzi
    • road kill
« on: May 18, 2017, 07:29:30 PM »
Did a few things ratting it up, 10 gallon tank from my T3, standard handlebars, floor boards from a T with the frame rails, EV fenders, Givi bags, all ready for work travel. Test rides and today I notice a weird light banging noise between 2450 and 2500 rpm. Maybe cam chain, maybe the hydraulic lifters, maybe clutch. Try every rpm and it's the same, no matter the gear but rattles at 2450 and 2500 rpm. Figured it out and will tell you later!
JB
John Boettcher
Wonder Lake, IL
"I'll quit riding when they pry the handgrips out of my cold dead fingers"
Re: Is my 04 raTi ready to blow up?
« Reply #1 on: May 18, 2017, 08:09:18 PM »
Sidestand vibrating on the header?
« Reply #2 on: May 18, 2017, 08:13:06 PM »
Something's loose...
« Reply #3 on: May 18, 2017, 09:16:28 PM »
If you changed something and now a new thing is happening ....
.... It's something you changed, guaranteed ....
Offline ratguzzi
    • road kill
« Reply #4 on: May 18, 2017, 09:25:10 PM »
The winner!!! Exactly right! Motor must have a weirdness at 2475 rpm and yes, I watched the sidestand shake like a mother! . Because of the floor board rail change, the sidestand rode up to the header.
I saved thousands having it such a simple thing!
JB
John Boettcher
Wonder Lake, IL
« Reply #5 on: May 18, 2017, 10:39:52 PM »
 Yes -----
Offline Carlo DeSantis
« Reply #6 on: May 19, 2017, 12:47:53 AM »
Quote from: fotoguzzi on Today at 07:09:18 PM
JB
Had the same thing on my EV.  Must be a thing with that engine.  A little re-aligment of the header and all was well.
Best,
Carlo
Chuck in Illinois
Crystal Lake, IL USA
'75 850 T3 Custom
'11 R1200R
« Reply #7 on: May 19, 2017, 08:25:46 AM »
JB
Well, you sort of KNEW that the chances of a cam chain going bad at the same time you'd gone in and changed a floorboard rail were pretty darn slim ....  :bow:
Offline radguzzi
« Reply #8 on: May 19, 2017, 10:22:27 AM »
Backl when we had the 2000 Bassa I thought one side of the engine had a small end bushing going bad or actually already gone....  the rapping noise was right at a certain Rpm.
When I got her into the garage for inspection I found the front engine bolt had a slightly loosened and the washer on the side with the nut was causing the sound... fhew...!
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline ratguzzi
    • road kill
« Reply #9 on: May 19, 2017, 03:07:22 PM »
A simple piece of steel with a small piece of velcro on the bracket to prevent any noise. The tab that helps you retract the kickstand was the culprit.
JB
John Boettcher
Wonder Lake, IL
« Reply #10 on: May 19, 2017, 05:46:24 PM »
I was down in Louisiana when I first heard a noise like that. Rode it 1100 miles on pins and needles until I found it once I was home.  :grin: Duh.
