Author Topic: Engine noise, V7II Stone  (Read 2471 times)
Offline alanp
« on: May 20, 2017, 05:13:38 PM »
I have a noise that sounds like valve tappet noise, but I am not convinced it is.  When I first heard the loudish tap, tap, tap coming from the right valve cover area (only the right, not the left) I figured I needed to check the clearances.  Turned out the clearances were exactly the same on both sides, with the exhaust being exactly on spec (.020) and the intakes being a tad loose (.017 vs. .015 spec).  I left them as is and closed it back up.  The tap persists, but there are couple of differences from typical Guzzi tappet noise I am used to.
At idle, the left side sounds normal to me.  The right side has a pronounced ting/ping noise.  It sounds louder and "ringier" than the tappet noise I am used to from other Guzzi engines, but this is my first small block.  The sound is more like hitting a tuning fork as opposed to hitting a piece of rebar. Ringy, and really quite noticeable when I start the bike cold.  But it gradually goes away as the bike warms.  After 5 miles, the noise is less loud.  After 10 or 15 it is gone, and the left and right sides sound identical.
Any ideas?
Niwot, Colorado
'16 V7II Stone - Black
Previous Guzzis
Re: Engine noise, V7II Stone
« Reply #1 on: May 20, 2017, 05:24:32 PM »
Fins ringing? Are the buffers still there?
Offline redhawk47
  • Traveler
« Reply #2 on: May 20, 2017, 11:24:36 PM »
Alan,
Check the header nuts. I had a similar noise and one of them was about to fall off and two more were loose. Seems to be a common problem on V7's.
I am ordering some Nordlock washers for mine.
Dan
« Reply #3 on: May 21, 2017, 06:02:43 AM »
Alan,
Also check the positioning of the exhaust. Is something close enough that vibration is making the exhaust contact it.
IIRC I loosened up all 4 header nuts and tweaked the left-to-right positioning of the whole system JUST enough to keep the crossover from just barely contacting something on the frame.
