I got a cheap Chinese set from Northern Tool or Harbor Freight, 4 sizes $75
Dusty, I have simply welded a bead on the race,a known trick... When it cools the bead shrinks and the race falls out... This worked on many situations including Guzzi swing arm races....Of course it ruins the bearing
I got a steering wheel puller for my Griso pulley from Autozone. They loan tools out for free!
This is a roller bearing , and a new one at that . The mechanic made an understandable mistake and caught it before any harm was done . He just needs to remove the bearing, preferably W/O damage . There were two bearings that were the same OD , different ID . Dusty
I believe the mechanic needs to get a bearing puller
That's Blind Lemon Pledge...
Dang , ask a serious question trying to help out a brother , and you guys go all goofy . Next time I'll ask a Harley forum Dusty
If you have one, you might try Autozone or O'Reilly auto parts stores; both will loan you tools. (Actually, you buy the tool, use it and then return it for the full purchase price refunded.)
I was going to suggest just close your eyes, but I won't now. Seriously Dusty, getting it out without damaging the bearing may be tricky. Can you heat the area where the bearing is? Sometimes if the clearance is not too tight they will drop out. (If the casting is alloy; greater expansion than steel)
I have the harbor freight set. it is a POS and failed on first use when pulling the pilot bearing out of a toyota truck crankshaft. i can't recommend it.
I have an update from the players. Bearing is out. Massive application of heat gun and other persuasion. Bearing undamaged. They say thanks all for the help, and also that the sense of humor around here is questionable.
i have a heat gun that i use for shrink wrap. its actually fairly hefty. i have used it on bearings that are set into an aluminum casting and it works a treat. the pilot bearing for the toyota was set right into the crank - steel on steel. i don't know whether or not a heat gun would have helped there because the crank is a huge heat sink and we would have just heated up the bearing instead - which would have made it even more difficult to remove. i'm willing to give this a go next time if your experience indicates that it works. i'm always looking for tips like this. thanks.
