Author Topic: Thanks Chet .Throttle linkage issue fixed  (Read 1292 times)
« on: July 01, 2017, 02:45:38 PM »
 So I mentioned experiencing a throttle issue on the old Jackal . Could only turn the grip about a quarter of a turn . Cables are fine , everything looks copacetic , still having the problem . Had started the old girl sitting right next to Luap's MGX 21 with the , er , melodious mufflers , so I didn't hear it cough . The right hand throttle body had moved back just enough to cause the crossover linkage to contact the airbox . Quick call to Mr Rugg , took a couple of minutes to explain the situation , he goes over my procedure , then says , "Oh , check to see if the linkage is hitting the airbox" . Well duh , if I had simply pushed the TB back into place the problem would have been eliminated  :laugh:
Anyway , thanks Chet  :bow:
Re: Thanks Chet .Throttle linkage issue fixed
« Reply #1 on: July 01, 2017, 05:07:26 PM »
 That's why they did the dual throttle cable recall.. so you could manually close the throttle if the linkage interfered with the air box.  :rolleyes:
Offline Chet Rugg
  • Administrator
  • Chet & Rusty ( 99 Bassa )
« Reply #2 on: July 01, 2017, 11:38:05 PM »
yep keep clearance at the air box use one throttle cable.
you are very welcome Dusty. had to use my brain to fix that one over the phone.
could not have done that with text messages  :thumb:
Chet Rugg
99 Bassa
01 Cali Special
100,000 miles
