Author Topic: 2011 V7C - GuzziDiag Question  (Read 1084 times)
Offline mthydro
« on: July 13, 2017, 12:21:46 PM »
Hi, I've read through the long GuzziDiag tutorial, but have a few questions before I do anything with it.
I have the lonelec cables, reader and writer has been downloaded, and drivers for cable will be downloaded.
Would these be the correct steps:
1. I'm guessing the first step will be to backup the bike's current map
2. Do I need to upload a file like this TunerPro XDF 15RC V7 V2.16 from here http://www.von-der-salierburg.de/download/GuzziDiag/
3. Reset TPS?
I appreciate the advice as I really don't want to screw anything up!
Mike
« Last Edit: July 13, 2017, 12:23:05 PM by mthydro »
2011 Moto Guzzi V7 Classic
1986 Vespa PX177E
Re: 2011 V7C - GuzziDiag Question
« Reply #1 on: July 13, 2017, 05:17:46 PM »
Unless you are planning on modifying the map yourself you have no need for Tunerpro.
The actual tuning functions like recalibrating the TPS and clearing the trims are under the 'Actors' meany in Guzzidiag.
beetle
« Reply #2 on: July 13, 2017, 05:34:11 PM »
Do not try to upload an XDF file. They are for use with map editing software only.
If you are only saving your current map, there's no need to reset the TPS. That is only required if you have flashed a new map, or are balancing your throttle bodies.
